superstock springs-lowering blocks??-69 r-r #234005
02/23/09 05:21 PM
02/23/09 05:21 PM
st.charles,mo.
dodgem1 Offline OP
dodgem1  Offline OP
st.charles,mo.
hi,i have a 69 r-r it has (
stupid stock )springs on it,i just got he car,i moved front to top hole,i would like to get about 2 more inches,what about lowering blocks-thanks-jeff
Re: superstock springs-lowering blocks??-69 r-r [Re: dodgem1] #234006
02/23/09 06:05 PM
02/23/09 06:05 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I ran 2" lowering blocks b-4 I switched to cal-tracs and still do w/out any issues but, make sure you use good billet ones not the cheap pot metal hollow ones sold locally.
Re: superstock springs-lowering blocks??-69 r-r [Re: Thumperdart] #234007
02/23/09 08:39 PM
02/23/09 08:39 PM
cincinnati ohio
mcat4321 Offline
mcat4321  Offline
cincinnati ohio
a 4x4/off road center should have billet ones , they even make some with an angle on them to help with seting pinion angle
Re: superstock springs-lowering blocks??-69 r-r [Re: dodgem1] #234008
02/23/09 09:13 PM
02/23/09 09:13 PM
Connecticut
5126brl No more Offline
Connecticut
I ran 1" cast allum blocks, lasted about a year before spliting.
Just did a set of 2" cast iron truck blocks and had then angle milled for pinion angle.
Re: superstock springs-lowering blocks??-69 r-r [Re: 5126brl No more] #234009
02/23/09 09:18 PM
02/23/09 09:18 PM
K
KOS Offline
KOS  Offline
K
i run 2"billet on my 9sec mid 1.3s 60fts for over 10years now.
Re: superstock springs-lowering blocks??-69 r-r [Re: KOS] #234010
02/24/09 09:53 AM
02/24/09 09:53 AM
Swamps of South Jersey.
W
wildcargo Offline
wildcargo  Offline
W
I have bin running 2" alum billet blocks for a log time.
There was a post on here with a set that you could change the angle on by changing a small plate on top, looked like a real nice setup to me.
Bud www.wildcar-go.itgo.com
64 DODGE
60' 1.433,
1/8 6.38 at 107.4,
1/4 10.08 at 132.02
foot brake, leaf springs
Re: superstock springs-lowering blocks??-69 r-r [Re: wildcargo] #234011
02/24/09 11:18 AM
02/24/09 11:18 AM
, PA
sleepyhead416 Offline
, PA
Turn the front bracket upside down.
