440 intake question
#2339661
07/19/17 12:38 PM
07/19/17 12:38 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
Customer car. 511 ci 440 base. Needs an intake carb air cleaner combo that will fit under a 70 road runner hood
I wanted to get a 4150 victor but dont think it will fit
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
Re: 440 intake question
[Re: sixpackgut]
#2339677
07/19/17 01:06 PM
07/19/17 01:06 PM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Still available new.......street dominator, torker 2...... Not sure about an rpm fitting(probably depends on the filter). 6bbl fits.
Used....... M1, torker, tm7.
4150 carb with a drop base style filter.
The SD, torker, tm7 will have room for a carb spacer.
[Re: sixpackgut]
#2339687
07/19/17 01:20 PM
07/19/17 01:20 PM
sixpackgut
Charleston
Forgot about the SD! Thats perfect. Thank You
