Electric fuel pump or mechanical
#2339255
07/18/17 06:34 PM
07/18/17 06:34 PM
Posts: 141 Ohio, USA
Donny
Ohio, USA
Doing my fuel system, 408, street car that will see track 3 times a year, 490hp, 950cfm carb, head work done at modern cylinder head. Engine has been on engine dyno only so far and broken in, so I have not driven it on street yet.
Here's what I have, new pick up in tank 1/2" IIRC, no return line in sending unit, 110g electric pump (holley blue design). I'm not married to the idea of this pump as I've not used it. But I'm reading and receiving mixed advice.
Is a return line a must for a street car? Are there more cons with electric v mechanical? Do I need return line with mechanical if I go that route?
Re: Electric fuel pump or mechanical
[Re: Donny]
#2339279
07/18/17 07:11 PM
07/18/17 07:11 PM
Posts: 13,380 Marion, South Carolina [><]
an8sec70cuda
From my experience w/ pump gas and street cars, I'd want an electric pump w/ a return line. The gas keeps getting worse and worse it seems and heat does bad things to it at the worst times when you're out trying to have fun in your hot rod.
[Re: Donny]
#2339288
07/18/17 07:29 PM
07/18/17 07:29 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
I have a racepumps 2000 mechanical on my 572 with a return line. I have yet to try it out. Tim
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: Donny]
#2339331
07/18/17 08:59 PM
07/18/17 08:59 PM
Posts: 52,972 Romeo MI
MR_P_BODY
That 110 pump will be to small if you race it... might just get a larger one now.. the 1/2" supply is plenty for you
[Re: Donny]
#2339357
07/18/17 09:24 PM
07/18/17 09:24 PM
MR_P_BODY
I might go FI in 3-4 years so I will redo the entire fuel system then, for now I'm sticking with simplicity and going with a good basic pump (electric or mech) that will fill my needs. I should add it is a half filled block so the oil will run hotter and have been told that could make the mechanical fuel pump hotter as well, giving me more reason to run a return line. I just added FI and have a return.. but I have been running a return for years now.. you might want to add that if you plan of FI in a couple of years.. just dont hook it up if you dont want to
[Re: Donny]
#2339616
07/19/17 11:24 AM
07/19/17 11:24 AM
Posts: 1,942 Metro Detroit
OUTLAWD
Metro Detroit
I might go FI in 3-4 years IMO this changes everything. I would run an intank walbro style 340LPH pump and a regulator that will work at both carb and EFI pressures. A 340LPH pump will easily support 600 HP at EFI pressure, and will support 800+HP at carb pressure. The Aeromotive Phatom line is designed to go into a stock style tank, but a number of other companies have similar solutions. When you go to EFI, you will have to swap a spring in the regulator and hit the road...In tank pumps are quiet and stay cool. Do it once now and be set. I always run a bypass return.
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts 66 Belv. II - just a streetcar 88 Mustang - turbo LS beater
[Re: Donny]
#2339649
07/19/17 12:27 PM
07/19/17 12:27 PM
Posts: 715 Central TEXAS!!!!
sr4440
Central TEXAS!!!!
I must be missing something. The OP says he already has a holley 110 pump, Holley rates that pump @ 88GPH at 9 PSI. The op’s engine makes 500HP (corrected). When doing the MATH, that pump is more than enough (IMO). Let’s run the numbers. 500HP X .5 PPH / 6 (weight of fuel) = 41.66 GPH. Now having over 112% reserve seems like enough to me. And the OP will be running, for the most part, in air that is not as good as “corrected” air, so he will need even less fuel.
I am sorry but I went down this road once. I had a car making 675hp with a holley blue pump and was told “pump is too small, you NEED a bigger one”. I didn’t have a lot of money, so I skimped, saved and sat out some races until I could get one. After all that it didn’t make the car ANY faster, so now if the numbers don’t make sense, I don’t do it.
Joe
Without Data, you’re just another guy with an opinion.
[Re: sr4440]
#2339654
07/19/17 12:35 PM
07/19/17 12:35 PM
Donny
Ohio, USA
Joe Thanks for input, I'm most concerned about safety and proper fuel intake for motor health, I'm not worried about what pump makes me go faster. The car is what it is, probably be a low 11 second maybe high 10 second car at best, and I'll live with that.
[Re: OUTLAWD]
#2339659
07/19/17 12:37 PM
07/19/17 12:37 PM
Donny
Ohio, USA
I might go FI in 3-4 years IMO this changes everything. I would run an intank walbro style 340LPH pump and a regulator that will work at both carb and EFI pressures. A 340LPH pump will easily support 600 HP at EFI pressure, and will support 800+HP at carb pressure. The Aeromotive Phatom line is designed to go into a stock style tank, but a number of other companies have similar solutions. When you go to EFI, you will have to swap a spring in the regulator and hit the road...In tank pumps are quiet and stay cool. Do it once now and be set. I always run a bypass return. Where can I learn more about this pump or approach, I'm intrigued.
[Re: Donny]
#2339681
07/19/17 01:13 PM
07/19/17 01:13 PM
OUTLAWD
Metro Detroit
