Brake Pedal Assemblies for B-Bodies with Automatic Trans
#2338960
07/18/17 11:43 AM
07/18/17 11:43 AM
Posts: 1,563 Macomb, MI
vinnyd76
Macomb, MI
Are brake pedal assemblies for B-Bodies equipped with an automatic transmission common from 66-70? A friend of mine is looking to install a brake pedal from a 70 B-body into a 66 B-Body.
Re: Brake Pedal Assemblies for B-Bodies with Automatic Trans
[Re: vinnyd76]
#2339261
07/18/17 06:39 PM
07/18/17 06:39 PM
Posts: 5,161 CT
GTX MATT
CT
No, the bracket is different. The 66/67 has a round hole for the defrost duct and the 68-70 is an oval. It will bolt in and work though, most '66/67s are missing the defrost vents/ducts by now anyway.
Also, its shaped differently where the clutch pedal stop is, not a big deal since his car is auto but if you mix and match clutch pedal and brake the clutch pedal stops too high or too low.
[Re: vinnyd76]
#2339298
07/18/17 07:51 PM
07/18/17 07:51 PM
Posts: 4,951 northwest USA
NANKET
northwest USA
That hole in the bracket is for the A/C duct to the far left side. The defrost ducts turn up when they exit the box and go straight to the ducts under the dash.
