Re: Stock trans limit? [Re: Hot 340] #2338840
07/18/17 01:49 AM
07/18/17 01:49 AM
Mopar Country, Mi
ccdave Offline
The Ultimate
ccdave  Offline
The Ultimate
Mopar Country, Mi
No need for a governor if the trans has no method to shift automatically with a manual valve body.
Re: Stock trans limit? [Re: Hot 340] #2338849
07/18/17 01:58 AM
07/18/17 01:58 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
Originally Posted By Hot 340
Originally Posted By GY3
I use a relatively stock one behind my 505.
I rebuilt it using better clutches, removed the governor, used a FWD pattern mvb and put the amount of springs in the front drum that Turbo action recommended. Other than that, it is pretty much stock.
It gets regular beatings on the track and street but I never do a 1st gear burnout, either!
Make sure you use a bronze thrust washer as most kits come with the fiber one and mine likes to eat those!
What does removing the governor do? (I am tranny stupid laugh2 )
It does nothing. Just another part to remove to eliminate the chance of having any issues and a tiny bit of weight loss.
Re: Stock trans limit? [Re: Shatar4] #2338851
07/18/17 02:10 AM
07/18/17 02:10 AM
Mopar Country, Mi
ccdave Offline
The Ultimate
ccdave  Offline
The Ultimate
Mopar Country, Mi
I also run a 505ci in a 70 Challenger with a 3:55 gear. Here is my 727 modifications:
Stock front drum with 5 thin Alto Red clutches and Colene steels
Modified rear drum with roller bearing 4 Alto Red and Colene steels
Billet rear support with roller bearing
A&A super sprague
Billet front and rear servos
Billet band struts
Turbo Action manual valve body forward pattern LBA
Aluminum deep pan
PTC 9.5" converter 3000 stall
No problems in 11 years and I built the trans myself with the help of the late Carl Monroe's book up
Re: Stock trans limit? [Re: Shatar4] #2338884
07/18/17 04:45 AM
07/18/17 04:45 AM
Planet Earth
RoadRunnerLuva Offline
Planet Earth
Originally Posted By Shatar4
None. I just dropped it so I can find someone that can look at it and beef it up. Anyone know someone in metro Detroit area?
Call Bobby at Reliable Transmissions in Waterford, on Dixie Hwy.
248-623-2230 ...He is a race car builder, and knows his transmissions. up
Plymouth Makes It!
Re: Stock trans limit? [Re: Shatar4] #2338930
07/18/17 10:54 AM
07/18/17 10:54 AM
A727Tflite Online content
A727Tflite  Online Content
You have a rebuilder and you are asking on this forum what is wrong with your trans?
You need a new rebuilder. He's the one that should be diagnosing your problem.
And fixing it. It's not your shifter.
Re: Stock trans limit? [Re: A727Tflite] #2338975
07/18/17 12:13 PM
07/18/17 12:13 PM
Howell, Mi
Shatar4 Offline OP
Shatar4  Offline OP
Howell, Mi
Now why would I go back for the third time? How many times do you get kicked by a mule before you realize it hurts? I'm not taking this trans out again so I took it somewhere else. Yea, the original guy has a warranty but what good is it if I have to keep taking it out?
Re: Stock trans limit? [Re: Shatar4] #2338982
07/18/17 12:21 PM
07/18/17 12:21 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
I can relate VERY much to what you say,That stuff set me back 2 yrs in my goals.
Re: Stock trans limit? [Re: Shatar4] #2339047
07/18/17 01:19 PM
07/18/17 01:19 PM
ok- if you aren't going back to him again - then you are on the right track. If you want it fixed correctly the First time PM me and I can get you fixed if you want.
Sorry - just saw you took it somewhere else.
