Re: Lexan scoop
[Re: ozymaxwedge]
#2337735
07/16/17 12:22 PM
07/16/17 12:22 PM
Posts: 19,376 Las Vegas
Al_Alguire
Las Vegas
Looks good...You might wanna slice a slot ion that hose between the vents though. Otherwise, well they cannot vent..
Re: Lexan scoop
[Re: Al_Alguire]
#2337831
07/16/17 03:35 PM
07/16/17 03:35 PM
Thumperdart
State of confusion
Looks good...You might wanna slice a slot ion that hose between the vents though. Otherwise, well they cannot vent.. Was thinking the same............Scoop looks good...........
Re: Lexan scoop
[Re: ozymaxwedge]
#2338012
07/16/17 09:59 PM
07/16/17 09:59 PM
Posts: 625 Oakville, Wa
HOTMOPR
Oakville, Wa
67 Barracuda, 470" B, Glide, FuelTech FT600, Precision, Ptc, QA1, Calvert, Smith racecraft, Afco, Dana 60. 275 radials
Re: Lexan scoop
[Re: Al_Alguire]
#2338086
07/16/17 11:19 PM
07/16/17 11:19 PM
Posts: 1,096 Australia
ozymaxwedge
Australia
Looks good...You might wanna slice a slot ion that hose between the vents though. Otherwise, well they cannot vent.. Hey Al, there is a 3/8 ish size hole on the under side of the hoses . Cheers
1963 Plymouth Max Wedge 1971 Barracuda
Re: Lexan scoop
[Re: Clanton]
#2338087
07/16/17 11:25 PM
07/16/17 11:25 PM
ozymaxwedge
Australia
Nice job!What glue did you use?
The only glue is on the back panel, it's a clear Araldite, nothing special, Base is 10mm or 3/8, top and sides are 6mm folded by the local plastics guy.
Re: Lexan scoop
[Re: ozymaxwedge]
#2338090
07/16/17 11:27 PM
07/16/17 11:27 PM
ozymaxwedge
Australia
Notice I have it offset ? just takes away a bit of the "That motor is not in the middle" look.
Re: Lexan scoop
[Re: ozymaxwedge]
#2338155
07/17/17 01:38 AM
07/17/17 01:38 AM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
Notice I have it offset ? just takes away a bit of the "That motor is not in the middle" look. if I were to run one that's what I would do just drives me nuts to look at a car and the scoop is offset to one side
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
Re: Lexan scoop
[Re: ozymaxwedge]
#2338162
07/17/17 01:48 AM
07/17/17 01:48 AM
Posts: 22,696 Bitopia
jcc
Bitopia
The only glue is on the back panel, it's a clear Araldite, nothing special, Base is 10mm or 3/8, top and sides are 6mm folded by the local plastics guy. You certain its lexan or plexiglass? I'd like to see any bell mouth carb stack, just to calm things down, as I suspect airflow is going to be turbulent and biased, IMO. It is pretty.
Re: Lexan scoop
[Re: ozymaxwedge]
#2338248
07/17/17 11:03 AM
07/17/17 11:03 AM
Posts: 13,375 Marion, South Carolina [><]
an8sec70cuda
That looks good! Hopefully it works good too.
Re: Lexan scoop
[Re: ozymaxwedge]
#2338738
07/17/17 11:49 PM
07/17/17 11:49 PM
Posts: 159 australia
charger410
australia
Looks cool 😎. Hope you made 2, Al
Peter. Australian Charger, alloy block injected 410in, w9 na 9.03@148 leafs 3000lb
1967 barracuda 605 hemi Stage5 millennium 8.2@170
