P5153840 Tremec trans
#2336479
07/13/17 01:45 PM
07/13/17 01:45 PM
Posts: 1,400 Trumbauersville PA
ric3xrt
Trumbauersville PA
Does anyone have any Information on what Tremec trans this was? It was available in the mid 2000s( I think) Not having any luck with Google on searching this trans.
Truth has no agenda, but those with an agenda make their own truth. Some of us are so open minded they only see their View
Re: P5153840 Tremec trans
[Re: ric3xrt]
#2336531
07/13/17 03:45 PM
07/13/17 03:45 PM
Posts: 17,892 S.E. Michigan
ZIPPY
S.E. Michigan
In that timeframe, the only Tremec we did anything with was the T56.
given the part number series I have to ask...Are you looking at a pull-out from first gen drag pak, or parts someone involved hung on to?
If you are, those should be viper t56s. They were only used to hold the engine in, and were all supposed to be rebuildable cores, but some new ones did get mixed in. After the program changed, I'm pretty sure a few folks ended up with a trans or two here and there.
If memory serves, but the time the T6060 came online, we were past P5155XXX.
Rich H.
Esse Quam Videri
[Re: ric3xrt]
#2336579
07/13/17 05:19 PM
07/13/17 05:19 PM
ric3xrt
Trumbauersville PA
I picked up a NOS Bell housing part Number P5153602 listed as 5.7,6.1 and 392 Hemi Bell housing for A833 and Tremec TKO(5 speed OD) The pamphlet in side the box has a parts list, and this trans PN was listed as a TKO 5 speed trans, The Pilot bearing that's in the parts kit with this bell housing, has a smaller inside DIA than the trusty old Mopar/Magnum but bigger then the GM's .59. I trying to find info on the trans. I guess the short answer I'm looking for is what input shaft was used on this transmission, if the trans was based on the GM TKO's or the Ford version. Thanks
[Re: ric3xrt]
#2336634
07/13/17 08:01 PM
07/13/17 08:01 PM
ric3xrt
Trumbauersville PA
It's all good Zippy, that's more information than I got from Tremec. I have a bunch of TKO parts laying around and I'm just trying to figure out if the input shaft is a off the shelf or a one off piece. Thanks
