Cam spec.s ?
#2335784
07/12/17 10:57 AM
07/12/17 10:57 AM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
I'm looking for a cam for my stock '68 383. I am adding a 4 bbl and dual exhaust with H.P. manifolds. otherwise it's stock. Going back into my New port. I have zero experience with cams.
I was wondering just what the stock specs would be.
I'm looking at a Hughes unit. They suggested one with a rough idle and poor vacuum, along with rear gar change.. I was not wanting that, power brakes and a heavy car. What I want is more torque. Here's what I am looking at. SEH1016BL-12 lift intake 0.320 exhaust 0.330 duration intake 210* exhaust 216* Is this preferable to the stock unit?
I have mechanical Aptitude. I can screw up anything.
Re: Cam spec.s ?
[Re: bboogieart]
#2335796
07/12/17 11:16 AM
07/12/17 11:16 AM
Posts: 6,095 Valencia, España
NachoRT74
Valencia, España
check a thread about 383HP 330vs335HP which has being discused latelly and will find the info about the stock specs between the 3 383 setups available by those years
Re: Cam spec.s ?
[Re: bboogieart]
#2336353
07/13/17 02:52 AM
07/13/17 02:52 AM
RapidRobert
I'm surprised Hughes recommended one with a rough idle/low vacuum & a gear change for your mild DD. I'd consider one of the Summit house grinds (there's 2, a mild & one very slightly hotter both of which have gotten good reviews. I have one uninstalled as of now. they are inexpensive.
Re: Cam spec.s ?
[Re: dogdays]
#2336823
07/14/17 10:08 AM
07/14/17 10:08 AM
NachoRT74
Valencia, España
If you are a Crower fan the 267HDP is a very nice 383 cam.
WHO SAY ME? LOL I think the Hughes seems you are looking at is a good option too ( in my theorical "knowledgement" ).
Re: Cam spec.s ?
[Re: dogdays]
#2336826
07/14/17 10:19 AM
07/14/17 10:19 AM
NachoRT74
Valencia, España
The Hughes 1016 has the same duration at 50 as the stock HP cam, but lift is 0.480 rather than 0.455 or whatever, and LSA is slightly tighter at 212 rather than 115 or so. Those two changes make it a better cam, Usually MP ( per what I have read ) never makes public the correct duration at 0.050 lift but a 85% estimation of the total duration... is like that on stock cams, or stock cams 0.050" duration is more exact ?
Re: Cam spec.s ?
[Re: NachoRT74]
#2336874
07/14/17 12:27 PM
07/14/17 12:27 PM
Posts: 102 Colo
PJ68RT
Colo
The MP correction factors for @.050 duration, as i recall, are 85% for aftermarket performance cams and 77.7% for stock cams. Using the 77.7 factor for stock magnum cam gives: 268*.777 = 208 284*.777 = 220 This site seems to verify these numbers: http://victorylibrary.com/mopar/mpcam-tech-c.htm
Re: Cam spec.s ?
[Re: bboogieart]
#2336980
07/14/17 04:52 PM
07/14/17 04:52 PM
Posts: 14,496 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I'm looking for a cam for my stock '68 383. I am adding a 4 bbl and dual exhaust with H.P. manifolds. otherwise it's stock. Going back into my New port. Based on that info, I take it this was originally a 2bbl motor. If that's the case, than a valve spring upgrade will be required for virtually any cam swap. Personally, for that application I feel the smaller summit cam would work just fine, along with a set of stock replacement hp springs. Swap out the valve seals while you're in there.
Re: Cam spec.s ?
[Re: PJ68RT]
#2337045
07/14/17 08:10 PM
07/14/17 08:10 PM
Posts: 43,157 Bend,OR USA
Cab_Burge
The 1969 1/2 M code six pack 440 motors where the only stock production 440 motors that came with the three bolt cams and the low taper lifters like the 426 Street Hemi motors came with Your right on the cam specs. on the 375 HP and 390 HP six pack motors being the same Ma Mopar has done some things on special package vehicles that make me really wonder why
Re: Cam spec.s ?
[Re: bboogieart]
#2337299
07/15/17 12:00 PM
07/15/17 12:00 PM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
This came up last month: https://board.moparts.org/ubbthreads/ubbt...tml#Post2321416For reference, Sealed power lists two stock replacement cams: The Sealed Power stock 2-bbl replacement cam #KC327 specs are 206/209@ 0.050" duration, 0.434"/0.431" lift, 113 LSA. The Sealed Power stock 4-bbl replacement cam #KC661 specs are 214/225@ 0.050" duration, 0.449"/0.464" lift, 115 LSA. The specs seem to be in-line, but not exactly, what the factory advertised. From the '71 Factory Service Manual, the 2-bbl cams is 260/268 advertised duration, 0.425"/0.435" lift, 113 LSA, Intake open 18 BTDC, Intake Close 62 ABDC, Exhaust Open 68 BBDC, Exhaust Close 20 ATDC, 38 degrees overlap. To get those valve events, the cam would need to be installed 112 centerline. The FSM for the 4bb cam is 268/284 advertised duration, 0.450"/0.458" lift, 115 LSA, Intake open 21 BTDC, Intake Close 67 ABDC, Exhaust Open 79 BBDC, Exhaust Close 25 ATDC, 46 degrees overlap. To get those valve events, the cam would need to be installed 113 centerline. The Hughes SEH1016BL is a nice cam for what you are doing. Specs 210/216@ 0.050", valve lift 0.480"/0.495", 112 LSA, install intake centerline 108 degrees. On paper the hughes cam looks to be "between" the two cams, but this does not take into account the rate-of-lift of the lobe profile. Most likely, the Hughes cam at 0.200" duration is as large as the factory 4-bbl cam, while having seat-to-seat valve timing close to the factory 2-bbl cam. These are good things, it should idle nice and make more power/torque through the entire power curve. Not sure what your compression ratio is 9:1+?, but if you had about a 2200-2500 stall converter, and maybe 3.23:1 gears I would suggest the Hughes SEH1620BL cam. I would not use the Whiplash (SMC2942BL) cam in you application. You will need to upgrade the stock valve springs. If they are stock, they likely need replaced (because of age/loss of pressure) no matter what cam you use.
Re: Cam spec.s ?
[Re: bboogieart]
#2337354
07/15/17 02:20 PM
07/15/17 02:20 PM
fast68plymouth
So. Burlington, Vt.
The main issue with trying to use any Mopar published info on running duration for the factory cams(or the MP cams for that matter), is they don't say at what tappet lift those numbers are for.
If using any of the "normal" industry standard checking points/lifts, the 268/284 figures for the factory hp cam aren't even close.
As is illustrated above, when using the SAE method/checking lift(.006/rocker ratio), an actual factory HP cam measured at 292/310 duration.
The last "292" MP 509 cam I checked was 305.5@.006....... So who knows what checking height they are using to arrive at 292.
Camshaft duration numbers without knowing the checking heights are about as useful as head airflow numbers without test pressures. It's just a number......that can't really be used as a basis for comparison.
