Re: Oil dip stick tube broke off?
[Re: FY1TA & 65 Wedge]
#233632
02/23/09 07:58 AM
02/23/09 07:58 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
How would you get this off without dropping the oil pan? (big block in 65 B body)...
Or do you have to drop the pan?
Ideas....
How much broke off? are we talking about the bottom 5 or 6 inches, or did the pull handle come off of the stick?
if there's a long section that broke off, you could pull the dip stick tube out of the block, leaving just the stick itself sticking out of the hole in the block, but if it's just the bottom couple of inches, then I'm afraid you'd have no choice but to drop the pan, at least enough to get a magnet in there to try and fish it out.
**Photobucket sucks**
[Re: 70Cuda383]
#233633
02/23/09 08:27 AM
02/23/09 08:27 AM
Posts: 1,443 Maryland
Dads426
Maryland
If it's still in the block, a slide hammer and something to hook the bottom of the tube like a bolt with the head cut down to fit in the tube. Just don't lose the bolt....
2012 422 Allstars NSS Champion 2013 422 Allstars NSS Champion 2014 422 Allstars NSS Champion
[Re: Dads426]
#233634
02/23/09 09:09 AM
02/23/09 09:09 AM
Posts: 9,982 Ansonia, CT
CJK440
Ansonia, CT
Find a wood screw that will bite into the tube and pull it out.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
