What size are the large brake brums? C body? #233566
02/23/09 01:38 AM
02/23/09 01:38 AM
Cambridge Idaho
RUMBLON Offline OP
RUMBLON  Offline OP
Cambridge Idaho
I used a cut down C body rear end 8 3/4 for my 67 dart. We rebuilt the thing but it needs the drums as they were missing.
Is this what I need? any ideas?
also, what do I measure to make sure I buy the right ones. I KNOW they are the large ones.
thanks
LETS TRY THIS ONE http://www.rockauto.com/catalog/moreinfo.php?pk=299737
RAYBESTOS Part # 2953 {PG Plus; Outside Diameter 13.62" / 5 Bolts / Finned}
Rear; 11" X 2-1/2" Brakes; Except Drum Marked MW
Re: What size are the large brake brums? C body? [Re: RUMBLON] #233567
02/23/09 01:39 AM
02/23/09 01:39 AM
Cambridge Idaho
RUMBLON Offline OP
RUMBLON  Offline OP
Cambridge Idaho
nuther
Re: What size are the large brake brums? C body? [Re: RUMBLON] #233568
02/23/09 01:40 AM
02/23/09 01:40 AM
Cambridge Idaho
RUMBLON Offline OP
RUMBLON  Offline OP
Cambridge Idaho
I guess I will also need the drum kit?
Re: What size are the large brake brums? C body? [Re: RUMBLON] #233569
02/23/09 01:42 AM
02/23/09 01:42 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Your Rock Auto link reads..
Sorry!
The page you're looking for either no longer exists or is temporarily unavailable.
You need 11" drums...
Re: What size are the large brake brums? C body? [Re: 1_WILD_RT] #233570
02/23/09 01:53 AM
02/23/09 01:53 AM
Cambridge Idaho
RUMBLON Offline OP
RUMBLON  Offline OP
Cambridge Idaho
WILD, NOT SURE WHY IT WONT SHOW THE LINK.
HERE ARE MY OPTIONS and I changed the one link above.
More Info
$36.89 $0.00 $36.89
RAYBESTOS Part # 2953R {Professional Grade; Outside Diameter 13.62" / 5 Bolts / Finned}
More Info
$47.79 $0.00 $47.79
RAYBESTOS Part # 1924 {PG Plus; Outside Diameter 12.62" / 5 Bolts / Not Finned}
Front; 11" X 2-3/4" Brakes
More Info
$108.79 $0.00 $108.79
RAYBESTOS Part # 1938 {PG Plus; Outside Diameter 12.725" / 5 Bolts / Not Finned}
Front; Police Car And Taxi; 11" X 3" Brakes
More Info
$116.79 $0.00 $116.79
ACDELCO Part # 18B13 {replaces 18028326 #18028326, 19176916}
DRUM,FRT BRK DURASTOP; 11 X 2-1/2IN BRKS, EXC DRUM MARKED M.W.
* Non-stock item--shipping delayed up to 3 business days
More Info
$44.79 $0.00 $44.79
ACDELCO Part # 18B460 {#89058320}
DRUM,FRT BRK DURASTOP; 11 X 2-3/4IN DRUM
More Info
$130.99 $0.00 $130.99
ACDELCO Part # 18B461 {#89058321}
DRUM,FRT BRK DURASTOP; w/POLICE or TAXI or H.D.; 11 X 3IN BRKS
Re: What size are the large brake brums? C body? [Re: 1_WILD_RT] #233571
02/23/09 01:54 AM
02/23/09 01:54 AM
Cambridge Idaho
RUMBLON Offline OP
RUMBLON  Offline OP
Cambridge Idaho
Sorry!
11x2 2 1/2 11 x2 3/4 or 11 x 3? and I am confused.
Re: What size are the large brake brums? C body? [Re: RUMBLON] #233572
02/23/09 01:54 AM
02/23/09 01:54 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
There were 11x2, 11x2.5, and 11x3. The backing plates are what determines width.
Re: What size are the large brake brums? C body? [Re: Jim_Lusk] #233573
02/23/09 01:59 AM
02/23/09 01:59 AM
Cambridge Idaho
RUMBLON Offline OP
RUMBLON  Offline OP
Cambridge Idaho
Jim, what do I measure on the backing plate?
Re: What size are the large brake brums? C body? [Re: RUMBLON] #233574
02/23/09 02:11 AM
02/23/09 02:11 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Measure the width of the shoe thats attached, assuming it belongs with that backing plate...
Re: What size are the large brake brums? C body? [Re: 1_WILD_RT] #233575
02/23/09 02:14 AM
02/23/09 02:14 AM
Cambridge Idaho
RUMBLON Offline OP
RUMBLON  Offline OP
Cambridge Idaho
Thnaks, I will measure it in the AM, thanks again
Re: What size are the large brake brums? C body? [Re: RUMBLON] #233576
02/23/09 02:06 PM
02/23/09 02:06 PM
Nunya CA
CR8CRSHR Offline
CR8CRSHR  Offline
Nunya CA
Big Dave...Bil here in VV. For Billies Satellite that I am working on, I used the 11 x 2 1/2 drums and shoes. I upgraded to the 11 inch size to give it better stopping performance. I have manual disc brakes on the front. Most of the C Body rear ends were either 11 x 2 12 or 11 x 2 3/4 brake shoes either width sized drums. I had the 11 inch backing plates already so a swap was all I needed to do with new hardware and shoes. If you really need some help here, I can get some extra parts I have here to you and you can get the drums and shoes from any parts supplier. As you know I have my C and my Brother's here at the house so no worries about what you might need. Oh...and most C Body backing plates were the 11 inch type with certain B Body's having 11 inch drums as well. Let me know what ya need...Bill
Re: What size are the large brake brums? C body? [Re: RUMBLON] #233577
02/24/09 01:19 PM
02/24/09 01:19 PM
Cambridge Idaho
RUMBLON Offline OP
RUMBLON  Offline OP
Cambridge Idaho
OK, here are the brake pads, they measure at 2 1/2 inches. So I just need 11x 2 1/2 drums--CORRECT?? And I already have the cylinders and will buy new pads and the drum kit to go with them. My backing plates are ok, arnt they? they measure at 11" per the pic at the top.
Re: What size are the large brake brums? C body? [Re: RUMBLON] #233578
02/24/09 01:20 PM
02/24/09 01:20 PM
Cambridge Idaho
RUMBLON Offline OP
RUMBLON  Offline OP
Cambridge Idaho
This is as they sit now!
Re: What size are the large brake brums? C body? [Re: RUMBLON] #233579
02/24/09 02:08 PM
02/24/09 02:08 PM
Nunya CA
CR8CRSHR Offline
CR8CRSHR  Offline
Nunya CA
Yep Dave...That is correct. 11 x 2 1/2 inch drums will work perfectly.
Re: What size are the large brake brums? C body? [Re: CR8CRSHR] #233580
02/24/09 03:27 PM
02/24/09 03:27 PM
Southern Maryland
klunick Offline
klunick  Offline
Southern Maryland
I ordered mine through NAPA last year. Watch out, they are heavy.
67 Barracuda FB 69 Superbee "Southern Maryland: If you want a good looking woman, you had better bring her with you"
Re: What size are the large brake brums? C body? [Re: klunick] #233581
05/15/09 03:34 PM
05/15/09 03:34 PM
Cambridge Idaho
RUMBLON Offline OP
RUMBLON  Offline OP
Cambridge Idaho
Re: What size are the large brake brums? C body? [Re: RUMBLON] #233582
05/15/09 05:26 PM
05/15/09 05:26 PM
BDW Offline
BDW  Offline
I'd measure the backing plate first.
Re: What size are the large brake brums? C body? [Re: RUMBLON] #233583
05/15/09 06:49 PM
05/15/09 06:49 PM
Charlotte, NC
446acuda Offline
446acuda  Offline
Charlotte, NC
If you're trying to do it on the cheap, 11 x 2.5 drums can be found in the junkyard on up to mid '80's trucks and especially vans--usually uncut and in good condition since the fronts do most of the braking.
Re: What size are the large brake brums? C body? [Re: 446acuda] #233584
05/15/09 06:55 PM
05/15/09 06:55 PM
Andrewh Offline
Andrewh  Offline
actually 2.5 inch pads should be for a 3 inch drum.
Re: What size are the large brake brums? C body? [Re: Andrewh] #233585
05/15/09 07:33 PM
05/15/09 07:33 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
