Eagle heads on a hellcat short block #2334378
07/09/17 10:50 PM
07/09/17 10:50 PM
Between a rock & a hard place
cudadoug Offline OP
cudadoug  Offline OP
I'm considering a hellcat crate shortblock for my gen 3 swap project to use with Eagle heads. My question is has anyone done this and the resulting piston to valve clearance?
I am being told that the Eagle heads on a 9:1 OE 5.7 will bump that to 11:1, but the piston to valve clearance will disappear.
Would the same be true for the hellcat shortblock??
Thanks in advance for your input!
Re: Eagle heads on a hellcat short block [Re: cudadoug] #2334381
07/09/17 10:59 PM
07/09/17 10:59 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Im not sure on Hellcat piston. I think the valve position between an Apache/Hellcat head and an Eagle are identical. The Eagle has a smaller valve diameter than a Hellcat so you might actually gain piston to valve clearance. Like any engine build worth its salt, clay it anyway. Compression wise I dont think you would get much over 10.1 though since chamber cc isnt to much less than a Hellcat head.
Mopar to the bone!!!
Re: Eagle heads on a hellcat short block [Re: cudadoug] #2334424
07/10/17 12:07 AM
07/10/17 12:07 AM
cudadoug Offline OP
cudadoug  Offline OP
Interesting. I wasn't aware of the hellcat head cc.
Re: Eagle heads on a hellcat short block [Re: cudadoug] #2334943
07/10/17 09:28 PM
07/10/17 09:28 PM
Wisconsin
Medlock51 Offline
Medlock51  Offline
Wisconsin
Like a real Hemi chamber these newer designs can take a one point higher compression number than a wedge head can handle.
Re: Eagle heads on a hellcat short block [Re: cudadoug] #2335030
07/10/17 11:20 PM
07/10/17 11:20 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
What do you mean? That the larger chamber allows higher compression under boost?
Re: Eagle heads on a hellcat short block [Re: cudadoug] #2335069
07/11/17 12:10 AM
07/11/17 12:10 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Hellcat has 9.5.1 Compression with IIRC a 70cc chamber, pretty sure the Hellcat head is same as Apache chamber wise. Eagle heads are 65cc chamber, so technically you're only reducing chamber volume 5cc instead of 20cc on an early 5.7 swap.
Re: Eagle heads on a hellcat short block [Re: joshking440] #2335596
07/11/17 11:08 PM
07/11/17 11:08 PM
Wisconsin
Medlock51 Offline
Medlock51  Offline
Wisconsin
No... the Hemi design eliminates much of the detonation that comes with a wedge design with sharp edges in the chamber and less than ideal flame travel.
Re: Eagle heads on a hellcat short block [Re: Medlock51] #2337043
07/14/17 07:54 PM
07/14/17 07:54 PM
dogdays Offline
dogdays  Offline
Keep telling yourself that.....
R.
Re: Eagle heads on a hellcat short block [Re: dogdays] #2337170
07/15/17 12:39 AM
07/15/17 12:39 AM
Wisconsin
Medlock51 Offline
Medlock51  Offline
Wisconsin
R.
I will... before I built my last blown early Hemi I talked to many of the best builders n the biz... everyone told me the same thing. If Gartlis tells me something about a Hemi I tend to agree...
Re: Eagle heads on a hellcat short block [Re: cudadoug] #2337303
07/15/17 12:06 PM
07/15/17 12:06 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Compare combustion chambers before you extrapolate early hemi info to a Gen III. Not even the same. May as well used SBC thinking as it's just as relevant.
Don't be the exception.
Re: Eagle heads on a hellcat short block [Re: cudadoug] #2337462
07/15/17 05:42 PM
07/15/17 05:42 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
They new Hemi chambers seem pretty efficient, they don't need much ignition timing for max power
Re: Eagle heads on a hellcat short block [Re: cudadoug] #2341019
07/21/17 04:14 PM
07/21/17 04:14 PM
gregsdart Offline
gregsdart  Offline
The new Hemis are detonation resistant due to charge motion, like quench creates. That and dual plugs.
