Eagle heads on a hellcat short block
#2334378
07/09/17 10:50 PM
07/09/17 10:50 PM
Posts: 3,245 Between a rock & a hard place
cudadoug
I'm considering a hellcat crate shortblock for my gen 3 swap project to use with Eagle heads. My question is has anyone done this and the resulting piston to valve clearance?
I am being told that the Eagle heads on a 9:1 OE 5.7 will bump that to 11:1, but the piston to valve clearance will disappear.
Would the same be true for the hellcat shortblock??
Thanks in advance for your input!
Re: Eagle heads on a hellcat short block
[Re: cudadoug]
#2334381
07/09/17 10:59 PM
07/09/17 10:59 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Im not sure on Hellcat piston. I think the valve position between an Apache/Hellcat head and an Eagle are identical. The Eagle has a smaller valve diameter than a Hellcat so you might actually gain piston to valve clearance. Like any engine build worth its salt, clay it anyway. Compression wise I dont think you would get much over 10.1 though since chamber cc isnt to much less than a Hellcat head.
Mopar to the bone!!!
[Re: cudadoug]
#2335069
07/11/17 12:10 AM
07/11/17 12:10 AM
72Swinger
Nebraska
Hellcat has 9.5.1 Compression with IIRC a 70cc chamber, pretty sure the Hellcat head is same as Apache chamber wise. Eagle heads are 65cc chamber, so technically you're only reducing chamber volume 5cc instead of 20cc on an early 5.7 swap.
[Re: dogdays]
#2337170
07/15/17 12:39 AM
07/15/17 12:39 AM
Posts: 170 Wisconsin
Medlock51
Wisconsin
Keep telling yourself that.....
R. I will... before I built my last blown early Hemi I talked to many of the best builders n the biz... everyone told me the same thing. If Gartlis tells me something about a Hemi I tend to agree...
[Re: cudadoug]
#2337303
07/15/17 12:06 PM
07/15/17 12:06 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Compare combustion chambers before you extrapolate early hemi info to a Gen III. Not even the same. May as well used SBC thinking as it's just as relevant.
