Re: 360 BLOCKS [Re: Porter67] #2333895
07/08/17 11:58 PM
07/08/17 11:58 PM
iowa
jtgts Offline OP
jtgts  Offline OP
iowa
that 2.0 is wrong sorry should have been .002
Re: 360 BLOCKS [Re: jtgts] #2333910
07/09/17 12:44 AM
07/09/17 12:44 AM
P
Porter67 Offline
Porter67  Offline
P
If thats one of the consistent details, you might jump to .003 or better.
Sure is interesting and I hope you solve it.
Re: 360 BLOCKS [Re: Porter67] #2334461
07/10/17 01:00 AM
07/10/17 01:00 AM
iowa
jtgts Offline OP
jtgts  Offline OP
iowa
thanks and you and me both cant keep doing this [censored]
Re: 360 BLOCKS [Re: Porter67] #2334468
07/10/17 01:12 AM
07/10/17 01:12 AM
Mopar Guru Larry Atherton made mention in his book that you want to use the "truck" #3 thrust bearing that has the 40% wider side flanges. throwing that in cuz you mentioned the #3 bearing issue
Re: 360 BLOCKS [Re: RapidRobert] #2335071
07/11/17 12:11 AM
07/11/17 12:11 AM
iowa
jtgts Offline OP
jtgts  Offline OP
iowa
its #3 rod bearing that keeps spinning not the main
Re: 360 BLOCKS [Re: jtgts] #2335114
07/11/17 01:11 AM
07/11/17 01:11 AM
Alright, I'd have to go now with the prior stated inadequate clearance.
