Re: RHS INDY 360X heads!!
[Re: madmax2]
#233487
02/23/09 12:46 AM
02/23/09 12:46 AM
Posts: 12,423 Kalispell Mt.
HotRodDave
Kalispell Mt.
Except the new bosses added for dual ex patterns and dual rocker set up they look exactly like the RHS heads I just sold. Those were VERY nice castings, machining and casting quality was great. Ports were very well thought out and way better than a regular magnum head. I think they are the best iron head short of a W2.
[Re: HotRodDave]
#233488
02/23/09 02:53 AM
02/23/09 02:53 AM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
I plan to get a pair real soon and do some work to them. I'll post info and pics as soon as I do. Hopefully we can do an engine with them and get some HP #'s as well! Brian
Brian Hafliger
[Re: Brian Hafliger]
#233492
03/03/09 12:26 PM
03/03/09 12:26 PM
Posts: 1,949 land of 10,000______'s
BDS871Cuda
I ran X heads on a 340 years ago, they made good power. I don't think they will do as good as RPM heads, but for $770 for new castings, you can't go wrong.
They say 550 HP. I would bet it would have to be a stroker with max porting.
Still a good deal.
Snap your neck, mega G-force launch, is all I want!
[Re: BDS871Cuda]
#233494
03/03/09 01:38 PM
03/03/09 01:38 PM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
Jesse Lackman made 520hp/548 tq IIRC on a 408 with some far from maxed out RHS 360HPST heads and a mildish (238@.050) hydraulic roller. the 360HPST heads were the starting point for these heads. here's a link to Jesse's engine threaddang it, looks like Jesse beat me (: about the only things these have in common with OEM "X" heads are the name and the fact they're iron......
[Re: HotRodDave]
#233495
03/03/09 01:41 PM
03/03/09 01:41 PM
Posts: 752 North Dakota
Jesse_Lackman
super gas
super gas
North Dakota
I didn't think of the dual ex pattern when I made my suggestions for the 360HPST to RHS a couple years ago, nice addition. I'd still like to see a version with the pushrod holes un machined or machined for offset rockers.
[Re: Jesse_Lackman]
#233496
03/03/09 02:19 PM
03/03/09 02:19 PM
Posts: 15,493 the boonies
aarcuda
the boonies
550 would be possible, I got 520 with a 236/242 cam;
Street 360/408 dyno results (520 CHP - 540 CTQ)
wow, those were incredible numbers. Im running a hughes solid cam in my 416 that is the 245/250 @ .050. my TA heads have been obscenely ported as well.
i want too know what secrets you put into that motor (i never dyno'd mine).
What would you shift that (or my motor) at if hughhes says its good to 6100 rpm?? Ive been hitting it at 6500.
[Re: aarcuda]
#233497
03/03/09 08:38 PM
03/03/09 08:38 PM
HotRodDave
Kalispell Mt.
Guys Guys Guys these heads are not the X heads we have had around for the last 41 years!
Flow is better out of the box both in terms of volume and quality of the air flow. The combustion chamber is WAY better than an X head. It has genourous quench areas no funky divots and the RHS has way better swirl and wet flow characturistics. Even if the X head was ported to make as much flow as a RHS head it still will not make as much power.
[Re: aarcuda]
#233500
03/03/09 11:22 PM
03/03/09 11:22 PM
Posts: 5,160 Texas
dannysbee
Texas
aar How do your heads flow?
Getting old just means you were smarter than some and luckier than others.
[Re: dannysbee]
#233501
03/03/09 11:45 PM
03/03/09 11:45 PM
aarcuda
the boonies
you got me there. I didnt pay to get them flowed. But I asked for the best he had and he said I got it. I have some other pictures but theyre at work. the pushrod hump is nonexistent. the valve guides in the port is thinned and tapered. looks really nice.
I should have had them flowed but he told me not to waste my money cause he's flowed these before. i can remember any more than that
