Chevy axle swap questions #2334624
07/10/17 11:58 AM
07/10/17 11:58 AM
Coastal Maine
Mr onetwo Offline OP
Coastal Maine
Good morning guys, I have a chance to obtain a set of axles from a 1987 Chevy 3500 i ton.The front is a Dana 60 kingpin and the rear is a Dana 70 dually with a trak-loc?.Both are 4.10 gears and in decent shape.The rear measures around 62 1/2" drum to drum.Is this worth picking up as an upgrade for my 1978 RC?
Re: Chevy axle swap questions [Re: Mr onetwo] #2334642
07/10/17 12:24 PM
07/10/17 12:24 PM
Canada
CTD5.9 Offline
CTD5.9  Offline
Canada
The front will have the extensions on the hubs, they will require either a weird offset on the rims or a swapped/converted front hubs. I do believe the spring pads are about a 1/2 inch different or something but that's easy to remedy.
It is definitely a huge upgrade if that is what you are looking for.
Re: Chevy axle swap questions [Re: Mr onetwo] #2335506
07/11/17 08:55 PM
07/11/17 08:55 PM
Wisconsin USA
themoparmanjc Offline
Wisconsin USA
Don’t Buy From Famous Bob AKA Bob McCarty in Oklahoma. He is a Crook!
