Gearshift linkage help,,, 70 Challenger
#2334067
07/09/17 01:43 PM
07/09/17 01:43 PM
Posts: 4,852 KENTUCKY
69CHARGERMD
KENTUCKY
Car previously had a 318/904 Currently with a 440/727
Is the linkage different ?? I do not see a place to mount the torque shaft mount on the trans Also,,the torque shaft coming from the shifter down thru the floor seems tight to the headers,,,
Would like to see some pics or comments on the way to use the existing shifter and what linkage I need,,, I do not see anything obvious on the side of the trans to mount the torque shaft plate to hold the rod coming down from the shifter,,,????
Re: Gearshift linkage help,,, 70 Challenger
[Re: 69CHARGERMD]
#2334101
07/09/17 02:15 PM
07/09/17 02:15 PM
69CHARGERMD
KENTUCKY
update,,, I just found out my trans does not have anything to accept the mount for the toque shaft plate,( different tail shaft ),, arrgghhhh ( trans is a back up that was rebuilt and i am using out of the race car ) Didn't realize there was any mount to deal with ,,,,,,
[Re: 69CHARGERMD]
#2334772
07/10/17 03:40 PM
07/10/17 03:40 PM
Posts: 25,899 Rio Linda, CA
John_Kunkel
Rio Linda, CA
These are the "ears" on the tail housing that mount the floor shift vertical shaft.
