Bolt through valve covers. #2333663
07/08/17 03:58 PM
07/08/17 03:58 PM
roanoke va
kbcuda Offline OP
kbcuda  Offline OP
roanoke va
Any one running valve covers like these on a big block with eddie rpm heads? Any tricks to making them work? The long bolts bind in the cover and I cant seem to get them don all the way.
https://m.summitracing.com/parts/MRG-6865BG
Re: Bolt through valve covers. [Re: kbcuda] #2333666
07/08/17 04:03 PM
07/08/17 04:03 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I had a similar problem with a set of cast Edelbrock valve covers, #1 the holes weren't quite on the mark with the heads and #2 the Allen bolts were way to tight in the bores, get a ream slightly larger than the bolts diameter, not a drill bit and open up the bolt bores in the cover, be sure to check how much meat you have in the covers before boring them open
Mike
Re: Bolt through valve covers. [Re: kbcuda] #2333668
07/08/17 04:07 PM
07/08/17 04:07 PM
roanoke va
kbcuda Offline OP
kbcuda  Offline OP
roanoke va
Opening at the bottom be enough or ream the whole length of the tube?
Re: Bolt through valve covers. [Re: kbcuda] #2333675
07/08/17 04:13 PM
07/08/17 04:13 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I ended up doing the entire tube/bore
