Weird MoPar interchangability.....
#23334
02/07/06 10:17 PM
02/07/06 10:17 PM
Posts: 16,478 Canada
CrAzYMoPaRGuY
Canada
I remember hearing a 1969 Barracuda hood would directly interchange with a 1973-1976 Dart a long time ago, though I never actually tried it so I don't KNOW it's true.
Is there any other weird interchanging that can be done...?
When I tried B body Wilwood discs on my 1969 C body front end, I found out that although my C body spindles had the Wilwood hub 1/4" farther away from the hub's base- the inner and outer bearings were the same part # and the swap was relatively easy....
CrAzYMoPaRGuY
Re: Weird MoPar interchangability.....
[Re: CrAzYMoPaRGuY]
#23335
02/07/06 11:13 PM
02/07/06 11:13 PM
Posts: 5,789 Hamilton, Ontario Canada
Magnum
That same 67 to 69 Barracuda can interchange their front and rear bumpers. Here's one I'm sure no one will ever use but it sure came in handy for me one time ago. Driveshaft from a 72 Dart 904, 7 1/4" perfect fit into a 79 New Yorker after 440, 727 and 8 3/4" swap. Wheels of any LH car which is has a metric 5 x 114 mm will fit our 5 by 4.5". The center register is a nice snug fit too. Caution: Don't try this at home the offset is 2.2L K car alternator with V belt. Direct bolt in.
[Re: Magnum]
#23337
02/07/06 11:39 PM
02/07/06 11:39 PM
CrAzYMoPaRGuY
Canada
Haha! Reminds me of my J body 1980 Cordoba LS- I met a guy at a swap meet, and talking with him, I told him I had an 8 3/4" rear end, a 440, and a 727 transplanted into my car. He then told me to find a long box 70's ClubCab Dodge pickup, and take the rear half of the two piece driveshaft, and it would bolt right in. Skeptical, I bought one at the wrecker, and sure enough.....
CrAzYMoPaRGuY
[Re: ph23vo]
#23339
02/08/06 12:11 AM
02/08/06 12:11 AM
Posts: 1,294 Under the big sky
stateline
Under the big sky
fury turn signal lenses fit superbirds...
They are super bird park lites )70 Fury III that is !
[Re: Rug_Trucker]
#23341
02/08/06 12:27 AM
02/08/06 12:27 AM
Turn signal switch and canceling cam from up to 1976 Dodge Vans will work in a 65' Coronet Steering column.
[Re: CrAzYMoPaRGuY]
#23344
02/08/06 12:52 AM
02/08/06 12:52 AM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
Dodge truck hood hinges are also the same as B-body hinges.
[Re: Chris2581]
#23345
02/08/06 01:04 AM
02/08/06 01:04 AM
I found that a Ford door striker bolt from the parts store would replace my broken one on my '71 Plymouth Satellite. Also, a Ford dust cap cover for the wheel bearings from parts store will fit also. The Mopar one was too small...
[Re: sthemi]
#23348
02/08/06 02:55 AM
02/08/06 02:55 AM
I'm taking note again keep on going
#23349
02/08/06 04:13 AM
02/08/06 04:13 AM
Posts: 3,472 Lubbock, TX
Erics5th
UsedtobeSatellite6
UsedtobeSatellite6
Lubbock, TX
Defroster vents from '71-up pickups and vans work on '63-'66 A bodys. Door arm rests from vans work on 4dr B bodys...probably others. The round dome light covers are found in alot of different models. Pedal dress up trim found on alot of Mopars work on B bodys. Remote trunk release from M bodys work on earlier cars. Inside door handles, window crank handles from trucks and vans work on B bodys. Guess if it works, why change it?
Eric
[Re: CokeBottleKid]
#23353
02/08/06 09:24 AM
02/08/06 09:24 AM
Posts: 1,864 Butler, PA
romanucci
Butler, PA
hmmm what output rating do they have .
I'm curious about that one, too. Does the K-car alternator still have an external regulator? Is it one field wire or two?
