Need a little 70's d100 schooling
#2332826
07/06/17 11:46 PM
07/06/17 11:46 PM
Posts: 1,935 Grove, OK
hosehead
Grove, OK
So I've been bitten by the dodge truck bug recently but I'm realizing I don't know a lot about them. I have a chance to buy a 73 d100 short bed from a buddy. It's cheap. I've always wanted a step side so I guess I'm mainly asking about bed interchangeability. Are the stepside beds scarce? Expensive? I've looked around locally and haven't seen much stepside stuff for sale. Any other parts hard to find? Also was wondering what else I should look for. Any known/common issues with these trucks? It's a 318/auto and the body is dry, so the mechanics and bodywork won't be an issue. Thanks in advance for any info and sorry to be such a truck newbie!
63 Plymouth savoy 65 d100 66 dart race project 58 plymouth suburban
Re: Need a little 70's d100 schooling
[Re: hosehead]
#2333062
07/07/17 01:33 PM
07/07/17 01:33 PM
hosehead
Grove, OK
Oh wow! Had no idea the beds were the same for that long! Thanks Rednuck! Good info!
[Re: hosehead]
#2333065
07/07/17 01:37 PM
07/07/17 01:37 PM
Posts: 3,921 Richmond, Indiana
19swinger70
Richmond, Indiana
Like he said - they are basic and dependable. Nothing fancy or cushy - just blunt force tools. I have had around 10 old dodge trucks ranging form 1972 - 1987. 2x4 and 4x4. All very reliable and I beat them like stepchildren!
My current beast is a 1975 1 ton dump truck. full time 4x4. I just picked it up last week - and i am going through it to get it the way i want. will be a handy tool to have around.
1970 340 swinger. sublime 1967 barracuda fastback BB 55 Plymouth Project
[Re: hosehead]
#2333285
07/07/17 08:27 PM
07/07/17 08:27 PM
hosehead
Grove, OK
Thanks for all the info guys! I think I'm going to pursue this d100!
[Re: hosehead]
#2333393
07/08/17 12:46 AM
07/08/17 12:46 AM
Posts: 10,552 Freeport IL USA
poorboy
Freeport IL USA
Just a note, though the step side beds were unchanged (other then the floor and other minor running changes) between the 53 and the 80 something end of production, there is a difference between a step side bed length and a non- step side bed length. A step side bed was usually 7 1/2' long, but a 9' long step side bed was available off and on through production, the 9' beds are pretty rare.
The short box, non-step side bed is 6' long and the long bed is 8' long. The short bed standard bed, and the 'short" step side bed are different lengths. The frames are different, the bed to frame mounting points are different, and the position of the wheel wells in relation to the bed sides between the two styles are different.
If the truck you are looking at is a non-step side short bed, a step side bed will not interchange without some major modifications. Gene
[Re: hosehead]
#2333453
07/08/17 03:33 AM
07/08/17 03:33 AM
hosehead
Grove, OK
Thanks for the info, Gene. I was wondering about this. I guess I need to brush up on how difficult it would be to make the switch to a stepside bed. The truck I'm looking at is a short box.
[Re: poorboy]
#2333716
07/08/17 05:52 PM
07/08/17 05:52 PM
Posts: 1,497 North East USA
BIGGERED
Reasonable Title
Reasonable Title
North East USA
Just a note. A step side bed was usually 7 1/2' long, but a 9' long step side bed was available off and on through production, the 9' beds are pretty rare.
The short box, non-step side bed is 6' long and the long bed is 8' long. The short bed standard bed, and the 'short" step side bed are different lengths. The frames are different, the bed to frame mounting points are different, and the position of the. Gene If this is true how was I able to bolt a sweptside bed off of a 1977 dodge truck onto the frame of a 1977 step side? Though this may be true for much earlier trucks I'm pretty sure it is not accurate for 1973 - 1980. I even believe there were additional step side bed offerings in the earlier years. Red
[Re: hosehead]
#2333753
07/08/17 07:04 PM
07/08/17 07:04 PM
hosehead
Grove, OK
Red! You're giving me hope! I may hit you up for advice if I get this truck!
[Re: hosehead]
#2334007
07/09/17 11:40 AM
07/09/17 11:40 AM
BIGGERED
Reasonable Title
Reasonable Title
North East USA
Additional swepty detail
Also after reviewing 74-77 they list 6.5' and 8' Utiline Boxes 74-77 and a 9' Utiline Box for 74.
72-73 Manual shows frames for D100 with multiple wheel bases in 73, 115"('72-73), 131"('73), 133"('73) and 149"('73)
Red
[Re: BIGGERED]
#2334535
07/10/17 07:10 AM
07/10/17 07:10 AM
Posts: 7,831 east side of Ohio
basketcase
east side of Ohio
The short box, non-step side bed is 6' long and the long bed is 8' long. The short bed standard bed, and the 'short" step side bed are different lengths. The frames are different, the bed to frame mounting points are different, and the position of the. Gene If this is true how was I able to bolt a sweptside bed off of a 1977 dodge truck onto the frame of a 1977 step side? Though this may be true for much earlier trucks I'm pretty sure it is not accurate for 1973 - 1980. I even believe there were additional step side bed offerings in the earlier years. Red I did the same...swapped a Sweptside bed off a '77 to a Stepside bed off a '78, bolted right on.
1981 Dodge D150 360 auto
