Re: magnum head ???
[Re: Dakota_Don]
#233294
02/26/09 03:25 PM
02/26/09 03:25 PM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
cheap magnum spring thread about gm 3100 springs if you read through this, you'll find most of the pertinent info. with your current mag spring IH, you're probably right on the edge of allowable if you swapped to the GM springs (you'd be looking at probably .045" clearance to coil bind when calculating it out). stock mag springs are ~240lb/in with less than 80 lb seat pressure, the GM ones are ~330-365 lb/in with about 90-110lb seat pressure with what you'd probably probably see for an installed height, which I'm guessing would be ~1.61" or so.
Re: magnum head ???
[Re: patrick]
#233295
02/26/09 04:29 PM
02/26/09 04:29 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
Also considering the bad small block pushrod geometry he should have a bit more than the .045 to coil bind.
The dealer charged me $125 for my last set of 16 springs and 16 retainers. I don't remember the individual prices but that is quite a bit less than the $10 a piece, that would be over $160 just in springs plus you would still need retainers.
Re: magnum head ???
[Re: dustpan man]
#233297
02/27/09 07:18 AM
02/27/09 07:18 AM
Posts: 166 Caldwell. Id
edbux
Caldwell. Id
Hughes has springs that will work, under $6 each. A set of retainers is $62. Thats $154 for the set and the springs don't coil bind until ".620 of lift, much more most people will ever need.
1967 Dart 270
360/727
