Re: Original fastener for a 69 Charger RT ballast resistor
[Re: cbusters]
#2333524
07/08/17 11:28 AM
07/08/17 11:28 AM
Posts: 675 MI
MI Mopar Works
MI
Isn't that the bolt with the "boat anchor" in it? Captured washer with the teeth on the back side? Yes, unless it is a very early 69. Then it would have the smaller head firewall bolt like 68 and older.
[Re: MI Mopar Works]
#2333602
07/08/17 01:36 PM
07/08/17 01:36 PM
Posts: 732 Michigan
BlueRacer69
Isn't that the bolt with the "boat anchor" in it? Captured washer with the teeth on the back side? Yes, unless it is a very early 69. Then it would have the smaller head firewall bolt like 68 and older. I didn't realize there was a difference between the 68 and 69 bolts. Interesting. Can anyone post a pic of the two bolts? Would like to see the difference.
[Re: Sixt8Chrgr]
#2333613
07/08/17 02:08 PM
07/08/17 02:08 PM
Posts: 4,951 northwest USA
NANKET
northwest USA
I don't agree with a difference in these bolts. I hav 67 thru 70 b-bodies and they all use the same bolts for ballast, voltage reg, starter relay. No mark In the head, no spinning washer and no teeth on the underside. See picture. I have LA and St Louis cars 67-70 all use these bolts. Those anchor bolts with washer and teeth are newer.
[Re: NANKET]
#2333702
07/08/17 05:25 PM
07/08/17 05:25 PM
Posts: 675 MI
MI Mopar Works
MI
I don't agree with a difference in these bolts. I hav 67 thru 70 b-bodies and they all use the same bolts for ballast, voltage reg, starter relay. No mark In the head, no spinning washer and no teeth on the underside. See picture. I have LA and St Louis cars 67-70 all use these bolts. Those anchor bolts with washer and teeth are newer. There are definitely 2 different bolts used between 68-69. The ones you have pictured are typical 68 style. You are right about the anchor marking ones being newer. I should have caught that. The anchor ones are identical to the original bolts other than the head marking. Original 69-70 bolts actually had a head marking that looked like a target almost. You can kind of see it in this picture on the ballast resistor and voltage regulator. The engine ground uses a different type of bolt entirely. (5600 original mile A12 69 1/2 Super Bee survivor)
[Re: pullandrag]
#2334173
07/09/17 04:28 PM
07/09/17 04:28 PM
Posts: 675 MI
MI Mopar Works
MI
MI Mopar Works would you mind telling me what the black wire is that goes with the blue/br on ballast I don't recognize that thanks! That is the idle solenoid jumper wire. Specific to A12 cars.
[Re: pullandrag]
#2334530
07/10/17 04:13 AM
07/10/17 04:13 AM
Posts: 1,145 ontario calif
ns1aar
ontario calif
If you can get to the back a nut works
NS1AAR
#2337250
07/15/17 09:15 AM
07/15/17 09:15 AM
Posts: 177 NC
Sixt8Chrgr
NC
I don't agree with a difference in these bolts. I hav 67 thru 70 b-bodies and they all use the same bolts for ballast, voltage reg, starter relay. No mark In the head, no spinning washer and no teeth on the underside. See picture. I have LA and St Louis cars 67-70 all use these bolts. Those anchor bolts with washer and teeth are newer. There are definitely 2 different bolts used between 68-69. The ones you have pictured are typical 68 style. You are right about the anchor marking ones being newer. I should have caught that. The anchor ones are identical to the original bolts other than the head marking. Original 69-70 bolts actually had a head marking that looked like a target almost. You can kind of see it in this picture on the ballast resistor and voltage regulator. The engine ground uses a different type of bolt entirely. (5600 original mile A12 69 1/2 Super Bee survivor) Where there two different types of ballast resistors used? The one you show clearly uses the same fastener as the VR, but my ballast resistor fastener hold is through the resistor itself and requires a longer fastener. Bill Rolik sells a fastener that is longer and would accommodate my application. BUT I don't want wrong fasteners on my car. I did not have the correct fastener in the BR to start with so I want the correct BR and the correct fastener. I don't recall my ground strap using a different fastener than the other firewall parts? I have the original ground strap and will look at the indention the fastener made on the strap to see if it is larger than the other firewall fasteners. I do have the original fasteners for the starter relay, VR....and thought ground strap. I am restoring a 69 Charger RT original drivetrain, sheetmetal, floors etc. local Charlotte car that I have known since I was 16. My neighbor owned the car.
