Need a little 70's d100 schooling
#2332826
07/06/17 11:46 PM
07/06/17 11:46 PM
Posts: 1,935 Grove, OK
hosehead
Grove, OK
So I've been bitten by the dodge truck bug recently but I'm realizing I don't know a lot about them. I have a chance to buy a 73 d100 short bed from a buddy. It's cheap. I've always wanted a step side so I guess I'm mainly asking about bed interchangeability. Are the stepside beds scarce? Expensive? I've looked around locally and haven't seen much stepside stuff for sale. Any other parts hard to find? Also was wondering what else I should look for. Any known/common issues with these trucks? It's a 318/auto and the body is dry, so the mechanics and bodywork won't be an issue. Thanks in advance for any info and sorry to be such a truck newbie!
63 Plymouth savoy 65 d100 66 dart race project 58 plymouth suburban
Re: Need a little 70's d100 schooling
[Re: hosehead]
#2333062
07/07/17 01:33 PM
07/07/17 01:33 PM
hosehead
Grove, OK
Oh wow! Had no idea the beds were the same for that long! Thanks Rednuck! Good info!
[Re: hosehead]
#2333065
07/07/17 01:37 PM
07/07/17 01:37 PM
Posts: 3,920 Richmond, Indiana
19swinger70
Richmond, Indiana
Like he said - they are basic and dependable. Nothing fancy or cushy - just blunt force tools. I have had around 10 old dodge trucks ranging form 1972 - 1987. 2x4 and 4x4. All very reliable and I beat them like stepchildren!
My current beast is a 1975 1 ton dump truck. full time 4x4. I just picked it up last week - and i am going through it to get it the way i want. will be a handy tool to have around.
1970 340 swinger. sublime 1967 barracuda fastback BB 55 Plymouth Project
[Re: hosehead]
#2333285
07/07/17 08:27 PM
07/07/17 08:27 PM
hosehead
Grove, OK
Thanks for all the info guys! I think I'm going to pursue this d100!
[Re: hosehead]
#2333393
07/08/17 12:46 AM
07/08/17 12:46 AM
Posts: 10,538 Freeport IL USA
poorboy
Freeport IL USA
Just a note, though the step side beds were unchanged (other then the floor and other minor running changes) between the 53 and the 80 something end of production, there is a difference between a step side bed length and a non- step side bed length. A step side bed was usually 7 1/2' long, but a 9' long step side bed was available off and on through production, the 9' beds are pretty rare.
The short box, non-step side bed is 6' long and the long bed is 8' long. The short bed standard bed, and the 'short" step side bed are different lengths. The frames are different, the bed to frame mounting points are different, and the position of the wheel wells in relation to the bed sides between the two styles are different.
If the truck you are looking at is a non-step side short bed, a step side bed will not interchange without some major modifications. Gene
[Re: hosehead]
#2333453
07/08/17 03:33 AM
07/08/17 03:33 AM
hosehead
Grove, OK
Thanks for the info, Gene. I was wondering about this. I guess I need to brush up on how difficult it would be to make the switch to a stepside bed. The truck I'm looking at is a short box.
[Re: poorboy]
#2333716
07/08/17 05:52 PM
07/08/17 05:52 PM
Posts: 1,497 North East USA
BIGGERED
Reasonable Title
Reasonable Title
North East USA
Just a note. A step side bed was usually 7 1/2' long, but a 9' long step side bed was available off and on through production, the 9' beds are pretty rare.
The short box, non-step side bed is 6' long and the long bed is 8' long. The short bed standard bed, and the 'short" step side bed are different lengths. The frames are different, the bed to frame mounting points are different, and the position of the. Gene If this is true how was I able to bolt a sweptside bed off of a 1977 dodge truck onto the frame of a 1977 step side? Though this may be true for much earlier trucks I'm pretty sure it is not accurate for 1973 - 1980. I even believe there were additional step side bed offerings in the earlier years. Red
[Re: hosehead]
#2333753
07/08/17 07:04 PM
07/08/17 07:04 PM
hosehead
Grove, OK
Red! You're giving me hope! I may hit you up for advice if I get this truck!
[Re: hosehead]
#2334007
07/09/17 11:40 AM
07/09/17 11:40 AM
BIGGERED
Reasonable Title
Reasonable Title
North East USA
Additional swepty detail
Also after reviewing 74-77 they list 6.5' and 8' Utiline Boxes 74-77 and a 9' Utiline Box for 74.
72-73 Manual shows frames for D100 with multiple wheel bases in 73, 115"('72-73), 131"('73), 133"('73) and 149"('73)
Red
[Re: BIGGERED]
#2334535
07/10/17 07:10 AM
07/10/17 07:10 AM
Posts: 7,831 east side of Ohio
basketcase
east side of Ohio
The short box, non-step side bed is 6' long and the long bed is 8' long. The short bed standard bed, and the 'short" step side bed are different lengths. The frames are different, the bed to frame mounting points are different, and the position of the. Gene If this is true how was I able to bolt a sweptside bed off of a 1977 dodge truck onto the frame of a 1977 step side? Though this may be true for much earlier trucks I'm pretty sure it is not accurate for 1973 - 1980. I even believe there were additional step side bed offerings in the earlier years. Red I did the same...swapped a Sweptside bed off a '77 to a Stepside bed off a '78, bolted right on.
1981 Dodge D150 360 auto
[Re: earlymopar]
#2339259
07/18/17 06:37 PM
07/18/17 06:37 PM
dogdays
A four headlight truck is basically a holdover 1964. So dimensions would be same as earlier. Does your truck have a nut on the end of the axle shaft?
R.
OP: '72 was the first of the new body style and had one-year-only front end suspension parts, so the fact it's a '73 makes it more desirable. As far as bed style, the short wide bed is in demand, too. I wouldn't stop the deal over a bed style issue. The truck is 44 years old, they don't come around in decent shape that often. I looked at an '84 from desert SW and was disappointed to have floor rustout. I was told here that that's common as drains get plugged and water gets inside. It's not a deal killer, but is something to check for.
[Re: hosehead]
#2341007
07/21/17 03:56 PM
07/21/17 03:56 PM
hosehead
Grove, OK
Thanks dogdays! I'm not totally against the wide bed but it's the one part of the truck that is damaged and I always wanted a stepside. Although, after some searching, it seems that finding a nice stepside bed may be a bit difficult, so who knows. Some real good info here though! I'll post pics here if I'm able to get the truck from my buddy. Thanks everybody for the help! You guys rule!
[Re: hosehead]
#2342443
07/24/17 02:53 PM
07/24/17 02:53 PM
Posts: 1,400 Trumbauersville PA
ric3xrt
Trumbauersville PA
About 45% of the SWB runs were step-bed during the 70s Metal floors started in 81, The company that pressed the sides for dodge was the same one that pressed the Chevy step bed sides, only difference is the ridges that Dodge requested, they were located in Kansans went out of business when GM went to the flare style plastic beds. Bed sides are the same from 55-85, bed got wider sometime in the late 50's.
Truth has no agenda, but those with an agenda make their own truth. Some of us are so open minded they only see their View
[Re: hosehead]
#2384522
10/09/17 04:23 PM
10/09/17 04:23 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
I notice an exhaust pipe poking out in front of the rear tire. Where is the gas tank? Behind the seat? Or is it one of those Heart Throb under the frame deals? I am wanting to put duels on my 78 and am not sure just how to go about it. Probably going to move my tank into the bed. I have a behind the seat tank, However, I'm not sure I wanna ride around with 20 some gallons of gas in the cab, behind the seat.
I have mechanical Aptitude. I can screw up anything.
[Re: QuickDodge]
#2468446
03/19/18 02:28 AM
03/19/18 02:28 AM
Posts: 31 FL, US
gdc5200
FL, US
A 318 powered truck is probably the most common. A 73 may have 4 wheel drum brakes.
Starting 1973, all V8 cars and light trucks came with front disc brakes.
There is no neutral safety switch in life
[Re: gdc5200]
#2468605
03/19/18 03:16 PM
03/19/18 03:16 PM
Posts: 2,684 Des Moines IA
Soopernaut
Des Moines IA
Starting 1973, all V8 cars and light trucks came with front disc brakes. Not 4wd trucks. 1975 was the 1st year for discs on them. The 74 Ramcharger may have had discs though. I'd have to look it up.
1970 Dodge d100/eventually going on a 77 D100 frame
[Re: hosehead]
#2468863
03/20/18 12:10 AM
03/20/18 12:10 AM
hosehead
Grove, OK
My little d100 has factory discs in front.
[Re: NV69B7RR]
#2469061
03/20/18 12:32 PM
03/20/18 12:32 PM
ric3xrt
Trumbauersville PA
In case you wanted to lower yours heres a really good looking truck. The "Tin grille Dodge Truck" group on facebook is pretty active and always has stuffer sale on it. Sharp truck
[Re: Soopernaut]
#2469074
03/20/18 12:45 PM
03/20/18 12:45 PM
ric3xrt
Trumbauersville PA
Starting 1973, all V8 cars and light trucks came with front disc brakes. Not 4wd trucks. 1975 was the 1st year for discs on them. The 74 Ramcharger may have had discs though. I'd have to look it up. Disk were standard on 4x2s starting in 72 (drums were an option) 4x4s disk were standard on ALL models under 400 series the heavier series had drum in till the SEG (special equipment group) closed shop After 35 years and parting out/scraping over 250 of these trucks I have only every come across 2 post 71's 4x4s with disk one was 72 W200 and the other was a 73W300
[Re: BIGGERED]
#2469079
03/20/18 12:49 PM
03/20/18 12:49 PM
ric3xrt
Trumbauersville PA
Hosehead
Here you go, this is for 78-81 things to note.
Box lengths both listed as 6.5" SW or SS
115" WB has 2 frames, D1 and W1 78-80, 81 is listed as separate part #s, this may be when the box mounting changed.
Note my 72-73 Manual shows a picture of the boxes but includes no panel part #, says order by description.
I have a 74-77 P Manual as well if you need more info.
Red
Rail stampings were identical between 4x2 and 4x4 only the X-members were different.
[Re: hosehead]
#2469140
03/20/18 02:38 PM
03/20/18 02:38 PM
Posts: 1,179 Canada
demon
Canada
No Dodge 4x4's came with disc brakes until 1975, except the 1974 Ramcharger.
[Re: NV69B7RR]
#2470182
03/22/18 01:33 AM
03/22/18 01:33 AM
Posts: 10,201 Someplace you aren't
SomeCarGuy
In case you wanted to lower yours heres a really good looking truck. The "Tin grille Dodge Truck" group on facebook is pretty active and always has stuffer sale on it. That’s sweet! What mirrors are those? and the air dam looks nice too, did you make it?
I want my fair share
