Converting from 2 piece shaft to 1 piece?r #2332379
07/06/17 10:23 AM
07/06/17 10:23 AM
ONTARIO,CANADA
604 Hemi GTX Offline OP
ONTARIO,CANADA
I'm wondering if anyone here has replace the 2 piece rear driveshaft for a 1 piece on a 2011 Ram 2500 4x4 crew cab long bed?
I've replaced three hanger bearings and now it needs a new one again.
I'm getting tired of replacing them so I was wondering if anyone knew were to get one or if you can get them from the dealer?
Thanks for any and all info
Kevin
Re: Converting from 2 piece shaft to 1 piece?r [Re: 604 Hemi GTX] #2332427
07/06/17 12:05 PM
07/06/17 12:05 PM
Richmond, Indiana
19swinger70 Offline
19swinger70  Offline
Richmond, Indiana
Have you had your shafts checked for balance? Something is wrong if the bearings are getting eaten up so quickly.
1970 340 swinger. sublime
1967 barracuda fastback BB
55 Plymouth Project
Re: Converting from 2 piece shaft to 1 piece?r [Re: 604 Hemi GTX] #2332514
07/06/17 02:31 PM
07/06/17 02:31 PM
Orange Park FL.
LilRed7879 Offline
LilRed7879  Offline
Orange Park FL.
Not the same truck but I replaced the two piece on my SRT10 after losing to bearings - felt much more solid than the 2 piece.
I had mine made at a local driveline shop
David S.
Part Time Owner
Dodge Connection
www.dodgeconnection.com
904-209-9388
Re: Converting from 2 piece shaft to 1 piece?r [Re: 604 Hemi GTX] #2332520
07/06/17 02:50 PM
07/06/17 02:50 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
That's going to be one very long shaft. I wouldn't do it.
Angry white pureblood male
Re: Converting from 2 piece shaft to 1 piece?r [Re: 604 Hemi GTX] #2332541
07/06/17 03:13 PM
07/06/17 03:13 PM
ONTARIO,CANADA
ONTARIO,CANADA
I've been reading on other sites that it's a common occurrence that the hanger bearings fail on these trucks.
I've had 2 failures because of bearings and now the second one for he rubber isolator failing.
I saw a company on eBay that builds aluminum driveshaft for these trucks and ive read mopar makes a shaft that will work but I can't find a part number
Kevin
Re: Converting from 2 piece shaft to 1 piece?r [Re: 604 Hemi GTX] #2332872
07/07/17 01:16 AM
07/07/17 01:16 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
My 06 megacab had a 2-piece. I replaced it with a factory one piece. Cost about $600 and has been on for about 75,000 miles now with no problems. The megacab was on the longest frame they made, but it's a 4x4 so the transfer case eats some of the length. Google around for the part number. I don't remember it off the top of my head
**Photobucket sucks**
Re: Converting from 2 piece shaft to 1 piece?r [Re: 604 Hemi GTX] #2334785
07/10/17 04:00 PM
07/10/17 04:00 PM
ONTARIO,CANADA
ONTARIO,CANADA
Ok so I came up with this part number
mopar 52123162AC But can't find info on length or dimensions.
Kevin
Re: Converting from 2 piece shaft to 1 piece?r [Re: 604 Hemi GTX] #2338275
07/17/17 11:40 AM
07/17/17 11:40 AM
Minneapolis, MN
hemi70se Offline
hemi70se  Offline
Minneapolis, MN
I have a 2014 6.7 AT mega cab and it came factory with a 1pc shaft. Megas and long box crew have the same wheelbase. Part # is 68241637AA list is $560 so if you can get 25% off or so it makes it a very reasonable price and you get new joints and slip yoke. If you look up a shaft for a 2008 model year its a lot more $ like $900
Re: Converting from 2 piece shaft to 1 piece?r [Re: 604 Hemi GTX] #2344784
07/28/17 12:26 PM
07/28/17 12:26 PM
Central Missouri Fort Leonard...
mopar65 Offline
mopar65  Offline
http://www.driveshaftspecialist.com/
I was going to use one of there shafts for my old 2011 Dodge 3500 LB Dully. But ended up trading it in on the truck I have now. A few guys on my Diesel truck site have them and really like them
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
Re: Converting from 2 piece shaft to 1 piece?r [Re: 604 Hemi GTX] #2344785
07/28/17 12:31 PM
07/28/17 12:31 PM
mopar65 Offline
mopar65  Offline
