Page 1 of 5 1 2 3 4 5
Bought my first 400 Block this Weekend #2248136
02/05/17 11:43 PM
02/05/17 11:43 PM
Taxes & Virus's R-US, NY
Dragula Offline OP
Dragula  Offline OP
Wasn't pretty, but it was unmolested and in very good condition...Gonna build a 440 source 512 this year out of it....
What heads (Indy) would you guys run in an A-body with 10.8:1 and just under .700 lift...I have EZ1 heads but was wondering if 440-1's would fit with my fender well headers and such...
Re: Bought my first 400 Block this Weekend [Re: Dragula] #2248184
02/06/17 12:32 AM
02/06/17 12:32 AM
Mid west
Gearhead383 Offline
Gearhead383  Offline
Mid west
I had no problems using 440-1s on my low deck in my Dart with either fenderwell headers or my Pro Parts headers.
Re: Bought my first 400 Block this Weekend [Re: Dragula] #2248243
02/06/17 02:03 AM
02/06/17 02:03 AM
My old 400 block pump gas stroker motor made the most power with a set of 440-1 CNC ported by Jeff at MCH shruggy
I tested two different motors with those heads and a set of Indy SR M.W. intake ports, the SR flowed 30 CFM less than the -1 did and the -1 heads made over 50 HP more than the SR heads did on the pump gas motor they made 65 more HP on the race gas motor shruggy Same short blocks, cams, intake and carb with no jetting or timing testing on either motor work
Go big for big power up
Re: Bought my first 400 Block this Weekend [Re: Cab_Burge] #2248731
02/06/17 09:43 PM
02/06/17 09:43 PM
Dragula Offline OP
Dragula  Offline OP
Really....50-60hp over the SR heads. I will have to look up and see where the EZ1 heads fall with respect to those...Mine flowed 330cfm at .700 if I remember correctly.
Re: Bought my first 400 Block this Weekend [Re: Dragula] #2248841
02/06/17 11:59 PM
02/06/17 11:59 PM
AndyF Offline
AndyF  Offline
I've made over 900 hp with EZ heads so I don't see much reason to step up to the SR or -1 heads unless you already have them. You might want to look at header options to see what works the best. You shouldn't need more than a 2 inch header for the combo that you're building.
https://www.youtube.com/watch?v=2zTAGAy081o
Re: Bought my first 400 Block this Weekend [Re: AndyF] #2250046
02/09/17 12:09 AM
02/09/17 12:09 AM
Dragula Offline OP
Dragula  Offline OP
Wasn't yours a dry sump?
Re: Bought my first 400 Block this Weekend [Re: Dragula] #2250075
02/09/17 12:40 AM
02/09/17 12:40 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Nice and although I don't make gobs of power, my 400 has proven well for over 14 years................ thumbs
Re: Bought my first 400 Block this Weekend [Re: Dragula] #2250339
02/09/17 03:10 PM
02/09/17 03:10 PM
Mt.Gilead, Ohio
OhioMopar Offline
OhioMopar  Offline
Mt.Gilead, Ohio
Gotta watch this... Similar build coming with much less head and in a street car...
1969 Dart GTS 340
1969 Super Bee X9 N-96
1969 Coronet R/T X9 N-96
2015 Dodge Dart GT
2019 Ram 2500 Big Horn.
Looking for the original block for my Bee. The last 4 are 7449
Re: Bought my first 400 Block this Weekend [Re: Thumperdart] #2251959
02/12/17 12:19 AM
02/12/17 12:19 AM
Dragula Offline OP
Dragula  Offline OP
So here is the block last week.....
Re: Bought my first 400 Block this Weekend [Re: Dragula] #2251961
02/12/17 12:25 AM
02/12/17 12:25 AM
Dragula Offline OP
Dragula  Offline OP
Here it is this week...
Re: Bought my first 400 Block this Weekend [Re: Dragula] #2252001
02/12/17 01:14 AM
02/12/17 01:14 AM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
B1 originals !
1.39 9.85 - 137 mph
Re: Bought my first 400 Block this Weekend [Re: Dragula] #2252057
02/12/17 03:45 AM
02/12/17 03:45 AM
My M.W. unported SRs flowed 340 CFM @.700, the ported 440-1 flowed 370@ .700 on the same bench shruggy
I didn't have a good set of dyno headers for the ported 440-1, the header flange protruded, blocked, into the lower exhaust port about 1/4 inch. They fit fine on the SRs but both motors I dyno tested the -1 heads started missing around 5200 RPM, it was a intermittent miss, not a steady dead cylinder miss confused It missed all the way up to and above peak HP RPM on both motors, the high compression race motor(526 C.I. 12.8 to 1 comp.ratio) missed worst than the smaller pump gas motor did (517 C.I., 10.8 to 1 comp. ratio) shruggy
Re: Bought my first 400 Block this Weekend [Re: Cab_Burge] #2331989
07/05/17 04:35 PM
07/05/17 04:35 PM
Dragula Offline OP
Dragula  Offline OP
So lots of progress and just waiting on push rods, but no way to post the full size pics thanks to photosucket holding my pics hostage...I have re-sized them and we will see how this goes.
Good news is, I found a use for that $900 oil pan that only holds about 8 quarts nobody wanted to buy!
Re: Bought my first 400 Block this Weekend [Re: Dragula] #2331991
07/05/17 04:37 PM
07/05/17 04:37 PM
Dragula Offline OP
Dragula  Offline OP
A few more pics...Shooting for 9.59 at 140mph next week with it, maybe.
Re: Bought my first 400 Block this Weekend [Re: Dragula] #2331992
07/05/17 04:38 PM
07/05/17 04:38 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Good luck man............ beer
Re: Bought my first 400 Block this Weekend [Re: Thumperdart] #2332003
07/05/17 05:00 PM
07/05/17 05:00 PM
Dragula Offline OP
Dragula  Offline OP
I had to steel the Milidon pump cover off the Hemi....The old covers had a smaller inlet port than the new ones. I never knew that....Now the Hemi needs another new style cover as we had to adapt to the AN16 oil line.
Re: Bought my first 400 Block this Weekend [Re: Dragula] #2332011
07/05/17 05:10 PM
07/05/17 05:10 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
The pulleys are for the alternator?
Good luck at the track!
Re: Bought my first 400 Block this Weekend [Re: Dragula] #2332042
07/05/17 05:55 PM
07/05/17 05:55 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Always something............. realcrazy
Re: Bought my first 400 Block this Weekend [Re: Dragula] #2332050
07/05/17 06:06 PM
07/05/17 06:06 PM
gregsdart Online content
gregsdart  Online Content
What heads did you wind up with? Flow?
Re: Bought my first 400 Block this Weekend [Re: gregsdart] #2332067
07/05/17 06:22 PM
07/05/17 06:22 PM
Dragula Offline OP
Dragula  Offline OP
Drives the water pump and alternator...Race car only stuff...lol
Heads are my old try'd and true Indy EZ1 heads...330cfm at .600" is all they are...too scared to try 440-1's due to Header A-body fitment...Went 9.70 in my 440
