A/F set up help
#2330989
07/03/17 08:23 PM
07/03/17 08:23 PM
Posts: 257 plainwell,michigan
1fastaspen
plainwell,michigan
Okay I got an aem a/f set up and I can't get this this to read at an idol it just says it's lean and shows no numbers if I bring it up around 1500 rpm it's at 17-18 I got a good ground and a full 12 volt power supply anyone else have this problem and if so what was the cure and yes this was a brand new in the box unit
75 duster 440 in the works
71 pro street cuda
Re: A/F set up help
[Re: 1fastaspen]
#2330991
07/03/17 08:26 PM
07/03/17 08:26 PM
Posts: 8,032 Tulsa OK
Bad340fish
Tulsa OK
If its real close to the exit of the exhaust it may not read until you get some RPM and exhaust flow, otherwise it will read a little bit of fresh air at low RPM. I have the same issue with my innovate LC2 when my exhaust dumps are open.
68 Barracuda Formula S 340
Re: A/F set up help
[Re: 1fastaspen]
#2330994
07/03/17 08:33 PM
07/03/17 08:33 PM
Posts: 4,287 Morrow, OH
markz528
Morrow, OH
Okay I got an aem a/f set up and I can't get this this to read at an idol it just says it's lean and shows no numbers if I bring it up around 1500 rpm it's at 17-18 I got a good ground and a full 12 volt power supply anyone else have this problem and if so what was the cure and yes this was a brand new in the box unit I had the same issue but once I adjusted the idle mixture screws it came right in. Did you try adjusted the idle mixture screws?
Re: A/F set up help
[Re: markz528]
#2331008
07/03/17 08:56 PM
07/03/17 08:56 PM
1fastaspen
plainwell,michigan
Yes I had them backed out like three turns lol and no change it's got an exhaust on it dumps at the rear tires and the sensor is about 6 to 7 inches past the end of the collector but it has short collectors on it
71 pro street cuda
Re: A/F set up help
[Re: FastmOp]
#2331040
07/03/17 10:26 PM
07/03/17 10:26 PM
1fastaspen
plainwell,michigan
I've looked at everything I can think of I even unhooked the evac system and no change but at 1500-2000 rpm it starts to read
71 pro street cuda
Re: A/F set up help
[Re: Sammy]
#2331048
07/03/17 10:37 PM
07/03/17 10:37 PM
1fastaspen
plainwell,michigan
Yes I did read that I'm going to let it run tomorrow and check the temp to see where it's at
71 pro street cuda
Re: A/F set up help
[Re: 1fastaspen]
#2331050
07/03/17 10:43 PM
07/03/17 10:43 PM
Posts: 12,226 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Don't worry about what it reads at idle. Set the idle where the engine likes it and don't even look at the O2. It doesn't matter. The preferred idle mix on different engine combos is all over the place. Besides, there are several other factors that could affect the readings and confuse the issue.
Does your engine have much lope? If so, then the more lope at idle you have, the more that will confuse your O2 readings at idle.
Master, again and still
Re: A/F set up help
[Re: DaveRS23]
#2331053
07/03/17 10:47 PM
07/03/17 10:47 PM
dartman366
Mt. Vernon, Ohio
Does your engine have much lope? If so, then the more lope at idle you have, the more that will confuse your O2 readings at idle. I agree, I use a LM-2 on my drag car and I din't pay much attention to the idle readings
Re: A/F set up help
[Re: 1fastaspen]
#2331144
07/04/17 02:20 AM
07/04/17 02:20 AM
Posts: 43,255 Bend,OR USA
Cab_Burge
What brand and how old is this unit?
Re: A/F set up help
[Re: Cab_Burge]
#2331202
07/04/17 09:20 AM
07/04/17 09:20 AM
1fastaspen
plainwell,michigan
I will look for air leaks today and it's an aem with the Bosch sensor and it's brand new
71 pro street cuda
