2002 5.9 1500 won't go into Park #2330760
07/03/17 04:35 PM
07/03/17 04:35 PM
Kentucky
dfsmopars Offline OP
Kentucky
A friend's '02 Ram 4x4 1500 won't go into park. Someone told him it is a tranny problem. True?
‘72 Charger, 5.9 Magnum, Tremec 5 spd., Pro-Touring
‘14 Big Horn, Quad Cab, 4x4, 1500
Re: 2002 5.9 1500 won't go into Park [Re: dfsmopars] #2330862
07/03/17 06:45 PM
07/03/17 06:45 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Check the shift linkage adjustment. Is this an all of a sudden thing or has he been having trouble with it and has he made any recent changes to the truck?
Re: 2002 5.9 1500 won't go into Park [Re: dfsmopars] #2331035
07/03/17 10:10 PM
07/03/17 10:10 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
4wd?t case in neutral will cause this. Course you wouldn't have drive either.
Angry white pureblood male
Re: 2002 5.9 1500 won't go into Park [Re: stumpy] #2331083
07/03/17 11:35 PM
07/03/17 11:35 PM
Kentucky
Kentucky
Shift linkage seems like the logical diagnosis but apparently it has been coming on intermittently and I feel pretty certain my friend would know it if the linkage was a problem. But you know what, I did not ask him just assuming his logical progression but I think it is still a good question for him.
Re: 2002 5.9 1500 won't go into Park [Re: dfsmopars] #2331110
07/04/17 12:42 AM
07/04/17 12:42 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Ask him if its hard to pull the shift lever into drive, or put it back in park. If the shift cable is getting bad, usually park is the first thing it won't go in. When you put the shifter in park, the linkage has to push the cable through the housing all the way to the end. If the cable is binding just a bit, it won't push it far enough to lock the park pin. There is an adjustment on the shift lever end of the cable, but if the cable is going bad, that adjustment won't fix it for long. Gene
Re: 2002 5.9 1500 won't go into Park [Re: dfsmopars] #2331246
07/04/17 11:28 AM
07/04/17 11:28 AM
Kentucky
Kentucky
He unhooked the cable/linkage at the tranny and the lever arm will not go into the park position.
Re: 2002 5.9 1500 won't go into Park [Re: dfsmopars] #2331278
07/04/17 12:25 PM
07/04/17 12:25 PM
SoMd, USA
135sohc Offline
135sohc  Offline
SoMd, USA
Rooster comb detent/detent ball.
Re: 2002 5.9 1500 won't go into Park [Re: 135sohc] #2332306
07/06/17 02:17 AM
07/06/17 02:17 AM
ST clair shores MI
moretoys Offline
moretoys  Offline
ST clair shores MI
the bar for the band came off, need to drop valve body, reinstall bar and adjust band.
Re: 2002 5.9 1500 won't go into Park- Update [Re: dfsmopars] #2348587
08/04/17 06:59 PM
08/04/17 06:59 PM
Kentucky
Kentucky
Reverse c-clip broke into three pieces. One piece went into the pan, one piece stayed in place and one piece got lodged in the shifting mechanism preventing it from moving all the way into park. The clip breaking is not unusual but I guess the piece getting stuck in the shifter is freaky.
