Re: Trying to start 69 d100 what is the minimum I need to start it
[Re: ryanf]
#2330818
07/03/17 06:35 PM
07/03/17 06:35 PM
RapidRobert
with what you have, confirm that it is wired right, if with the MSD/OE coil you tie the ign1 blue wire (run) circuit to the ign2 brown wire (crank) circuit then T from them to the coil positive primary & do/check the rest of the MSD basic wiring. both the MSD & the coil need to be hot in cranking and in run.
[Re: ryanf]
#2331980
07/05/17 04:04 PM
07/05/17 04:04 PM
Posts: 2,684 Des Moines IA
Soopernaut
Des Moines IA
The distributor is for an electronic ignition It is not stock for that truck. Is it a later engine?
1970 Dodge d100/eventually going on a 77 D100 frame
