tti Hemi header fitment issues...? #233033
02/22/09 07:08 PM
02/22/09 07:08 PM
florida
P
PJM Offline OP
PJM  Offline OP
P
florida
Any one out there that has tti headers on their hemi E body or B body have fitment issues? I have spent $900+ on these and have contact in 3 different areas (1. Front inside corner of steering box 2. Steering coupler 3. Passenger side torsion bar). Any help appreciated.
ps. Correct motor mounts and K member is dead on.
Re: tti Hemi header fitment issues...? [Re: PJM] #233034
02/22/09 07:19 PM
02/22/09 07:19 PM
Wisconsin USA
Bill MeLater Offline
Wisconsin USA
That's odd. $900.00 for $40.00 woth of steel and $50.00 worth off coating and they don't fit?
Re: tti Hemi header fitment issues...? [Re: PJM] #233035
02/22/09 07:24 PM
02/22/09 07:24 PM
Tampa FL
hemibeep Offline
hemibeep  Offline
Tampa FL
I believe I had to grind some of the motor mounts to "slide" the motor around. Also used a washer on one side or the other to "raise" the motor. I have manual steering, an it was tight. DId you check you tranny mount to make sure it was smooshed too low?
Re: tti Hemi header fitment issues...? [Re: Bill MeLater] #233036
02/22/09 07:26 PM
02/22/09 07:26 PM
pawling n.y.
cudachas Offline
cudachas  Offline
pawling n.y.
I just did this swap with 2 1/8 TTI's and arruzza mounts and the only contact I had was with the steering coupler. (manual box). I just put a flaming river coupler in and gained the clearance I needed. No steering box or torsion bar issues.Guess I was lucky. Charlie.
Re: tti Hemi header fitment issues...? [Re: cudachas] #233037
02/22/09 07:30 PM
02/22/09 07:30 PM
wisconsin
swifter Offline
swifter  Offline
wisconsin
I agree with bill me later--I have no choice but to use tti and the outrages price they charge they should go in by themselves -You also pay for the coating and they rust anyway--Go Badgers
2007 Ram 2500 Cummins 2008 Dodge Nitro 1970 340 Valiant Duster
Re: tti Hemi header fitment issues...? [Re: swifter] #233038
02/22/09 07:34 PM
02/22/09 07:34 PM
florida
P
PJM Offline OP
PJM  Offline OP
P
florida
For this kind of money they should fit without shimming or changing stock parts around. I am not happy!
Re: tti Hemi header fitment issues...? [Re: hemibeep] #233039
02/22/09 07:43 PM
02/22/09 07:43 PM
florida
P
PJM Offline OP
PJM  Offline OP
P
florida
Hemibeep. What do you mean about the tranny mount smooshed? I have a brand new mount in.
Re: tti Hemi header fitment issues...? [Re: PJM] #233040
02/22/09 07:55 PM
02/22/09 07:55 PM
Tampa FL
hemibeep Offline
hemibeep  Offline
Tampa FL
if you have new tranny mount you are ok there. might want to think out oil dipstick as well. I used a 440 one, if you need one, do NOT buy chrome one, tube does NOT want to go into the block.
Re: tti Hemi header fitment issues...? [Re: hemibeep] #233041
02/22/09 07:59 PM
02/22/09 07:59 PM
florida
P
PJM Offline OP
PJM  Offline OP
P
florida
Ok thanks
Re: tti Hemi header fitment issues...? [Re: PJM] #233042
02/22/09 08:23 PM
02/22/09 08:23 PM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
The factory k-members on these cars have real sloppy tolerances. The engine could be sitting in there way off from where it should be. Have you measured to make sure it is sitting in there according to TTI's instructions? My TTIs hit everywhere too (small block) and once I get the engine sitting in there according to TTI instructions they cleared everything and required no dents.
Re: tti Hemi header fitment issues...? [Re: 69Cuda340S] #233043
02/22/09 08:42 PM
02/22/09 08:42 PM
florida
P
PJM Offline OP
PJM  Offline OP
P
florida
Yes been through 2 k members.
