Performer rpm heads and valve covers #2329662
07/01/17 12:35 PM
07/01/17 12:35 PM
roanoke va
kbcuda Offline OP
kbcuda  Offline OP
roanoke va
Bought a nice set of fabbed aluminum valve covers with the long bolt- through design and seems the bolt holes in the head won't let these things work because of the angle of the holes.. Can you only use stock type valve covers with the thin flange with these heads??
Re: Performer rpm heads and valve covers [Re: kbcuda] #2329676
07/01/17 12:58 PM
07/01/17 12:58 PM
no actual exp with those heads but I would surely think the drilled/tapped holes in the head valve cover rails should be straight up.
Re: Performer rpm heads and valve covers [Re: kbcuda] #2329677
07/01/17 12:59 PM
07/01/17 12:59 PM
AndyF Offline
AndyF  Offline
Hard to tell without some pictures. Aftermarket heads generally have the valve cover bolts drilled and tapped perpendicular to the valve cover rail but maybe Edelbrock built some heads with the bolts at an angle? I've never seen that before but maybe you ended up with a set.
Re: Performer rpm heads and valve covers [Re: kbcuda] #2329686
07/01/17 01:15 PM
07/01/17 01:15 PM
mt. pleasant, PA
Diplomat440 Offline
Diplomat440  Offline
mt. pleasant, PA
The bolts in factory heads aren't drilled perpendicular to the valve cover surface from what i can tell, but the Edelbrock ones are.
Even though they are just slightly angled, you probably aren't going to be able to use a valve cover like that, that takes such a long bolt.
Re: Performer rpm heads and valve covers [Re: kbcuda] #2329960
07/01/17 10:22 PM
07/01/17 10:22 PM
Massillon, Ohio
cudatom Offline
cudatom  Offline
Massillon, Ohio
I used the mopar cast covers. They have been on and off( tried different valve clearances to see if I could pick up any et) several times in the past 3 yrs. No leaks. I used the moroso blue gaskets.
Ok
Re: Performer rpm heads and valve covers [Re: kbcuda] #2329966
07/01/17 10:35 PM
07/01/17 10:35 PM
roanoke va
kbcuda Offline OP
kbcuda  Offline OP
roanoke va
Was able to fenagle them on. Bolt binding on cover the whole time. With the cork gasket and drawn down as much as possible gasket was still loose and not compressed. Probably just end up with the mopar performance black finned ones.
Re: Performer rpm heads and valve covers [Re: kbcuda] #2330022
07/02/17 12:51 AM
07/02/17 12:51 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
The Indy ones work great.
