gen III to 727 s/b torqueflite #2328698
06/29/17 04:33 PM
06/29/17 04:33 PM
organ
maximum entropy Offline OP
organ
what is required to mate these two? thanks in advance,
karl
Re: gen III to 727 s/b torqueflite [Re: maximum entropy] #2328732
06/29/17 05:27 PM
06/29/17 05:27 PM
bonney lake washington
W
w2stroker Offline
w2stroker  Offline
W
AtI flexplate and normal sb converter
Re: gen III to 727 s/b torqueflite [Re: maximum entropy] #2332645
07/06/17 05:37 PM
07/06/17 05:37 PM
Colorado
3
303 Mopar Offline
303 Mopar  Offline
Colorado
You need the specific bolts for the flexplate too, and your 727 needs to be converted to full manual valve body for the drive-by-wire pedal.
Re: gen III to 727 s/b torqueflite [Re: maximum entropy] #2332910
07/07/17 04:06 AM
07/07/17 04:06 AM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
If you're running a carb, I would think you could the kick down via cable for a full automatic trans, yes?
