Green Axle Bearings. #2328401
06/29/17 01:19 AM
06/29/17 01:19 AM
Minnesota
mndartguy Offline OP
Minnesota
I have a pair of these that have had on the shelf for a number of years. Thinking about putting them in my Cuda. Anyone have any info about these that you would like to share? These are the "old" part number for the green bearings. Have heard some people have trouble with these....thanks
Re: Green Axle Bearings. [Re: mndartguy] #2328431
06/29/17 02:19 AM
06/29/17 02:19 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
The load carrying capability of the stock Timken tapered bearings is far superior. When these non adjustable bearings came out years ago, they made it seem like the stock bearing adjustment was such a pain to do. It isn't difficult, even for a novice.
Re: Green Axle Bearings. [Re: mndartguy] #2328463
06/29/17 06:57 AM
06/29/17 06:57 AM
Groningen, the Netherlands
4doorSatellite Offline
Snap-ring or crimped on flanges?
I've had trouble with the latter.
Re: Green Axle Bearings. [Re: Kern Dog] #2328469
06/29/17 08:35 AM
06/29/17 08:35 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
My thoughts exactly.
Re: Green Axle Bearings. [Re: Kern Dog] #2328558
06/29/17 01:15 PM
06/29/17 01:15 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
iagree X2
Re: Green Axle Bearings. [Re: mndartguy] #2328588
06/29/17 02:21 PM
06/29/17 02:21 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Seems most of the issues arise from individuals who lack the mechanical experience/knowledge to perform this task, often along with the lack of proper equipment to remove/press bearings, be it Green or factory tapered, hence: installation error
I've been using nothing but Green bearings for the last 3 decades+ on my cars or customers builds, ZERO issues, I still run a set I installed on my Challenger T/A almost 30-35 years ago, tens of thousands of street miles, street/drag racing and road course, HotRod Power Tours, cross country events/shows with all my toys running Green bearings
Almost every vehicle manufactured in the last 2+ decades runs on ball bearings
Re: Green Axle Bearings. [Re: DAYCLONA] #2328598
06/29/17 02:40 PM
06/29/17 02:40 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
here we go whistling catfight popcorn beer
Re: Green Axle Bearings. [Re: DAYCLONA] #2328663
06/29/17 03:54 PM
06/29/17 03:54 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
And, for the most part, the appeal of the Greens is to those individuals who are too lazy or too lame to properly adjust the tapered bearings.
Re: Green Axle Bearings. [Re: John_Kunkel] #2328673
06/29/17 04:02 PM
06/29/17 04:02 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
Well John, I'm neither lazy nor do I lack the knowledge to properly adjust the tapered bearings. I use the green bearings. Maybe you should refrain from painting everyone who prefers to do something different with such a broad brush. tsk
Abe Lincoln
Re: Green Axle Bearings. [Re: TJP] #2328676
06/29/17 04:03 PM
06/29/17 04:03 PM
milwaukee
superbird Offline
superbird  Offline
milwaukee
i like the green bearings its just so simple
Re: Green Axle Bearings. [Re: mndartguy] #2328701
06/29/17 04:34 PM
06/29/17 04:34 PM
Berlin, N.J.
abodyjoe Offline
abodyjoe  Offline
Berlin, N.J.
same set of green bearing are in our dart that we installed in the 90's. lots of beatings over the years.
talking with dr diff not all that long ago (who many here respect and worship) and he sells a ton of green bearings. he says they are very strong and will hold up just fine.
not sure why this thread was even started.. could have done a search and came up with a thousand threads on this subject. the same guys like and use them and the same grumpy haters don't like them and will insult everyone that uses them.. some things never change.
It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
www.MoparMisfits.com
Re: Green Axle Bearings. [Re: mndartguy] #2328720
06/29/17 05:02 PM
06/29/17 05:02 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
You couldn't pay me to use green bearings. Chrysler put the best axle bearings in there, why get rid of them? So easy to adjust them, but folks make it harder than it is.
I was helping a guy on the phone, he had .010 clearance, but since it has that on both side then it is .020! Oh brother, creating a problem.
Re: Green Axle Bearings. [Re: dart4forte] #2328787
06/29/17 07:39 PM
06/29/17 07:39 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Originally Posted By dart4forte
]Well John, I'm neither lazy nor do I lack the knowledge to properly adjust the tapered bearings. I use the green bearings. Maybe you should refrain from painting everyone who prefers to do something different with such a broad brush. tsk
You'll notice I said "for the most part". Maybe you should give us a lengthy dissertation on why you prefer them. Might make some converts.
Re: Green Axle Bearings. [Re: mndartguy] #2328799
06/29/17 07:59 PM
06/29/17 07:59 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Well, it's hard to put Jeep rear discs on without green bearings. Maybe you could machine out the center hole to fit the adjuster, but I dunno if it'd have enough meat left.
Don't be the exception.
