Synthetic oil or not? #2327278
06/27/17 12:01 AM
06/27/17 12:01 AM
Oklahoma
gregok Offline OP
gregok  Offline OP
Oklahoma
I am about due for an oil change on my 70 Road Runner with 440-6. What recommendations do you have for moving to a synthetic oil? good idea or not? TIA
Re: Synthetic oil or not? [Re: gregok] #2327634
06/27/17 06:17 PM
06/27/17 06:17 PM
Chicago, Illinois
Devil Offline
Devil  Offline
Chicago, Illinois
Re: Synthetic oil or not? [Re: gregok] #2327743
06/27/17 10:20 PM
06/27/17 10:20 PM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
Depends on usage. Synthetic may be an advantage or just an extra cost.
Also there are several base stocks that can be called "synthetic". There were some problems with early synthetics made entirely from one of the base stocks. Shouldn't be a problem with any reputable synthetic today.
Re: Synthetic oil or not? [Re: gregok] #2327777
06/27/17 11:14 PM
06/27/17 11:14 PM
MO
cdp Offline
cdp  Offline
MO
Brad Penn.
Re: Synthetic oil or not? [Re: gregok] #2327820
06/28/17 12:31 AM
06/28/17 12:31 AM
crlush Offline
crlush  Offline
Brad penn
Re: Synthetic oil or not? [Re: crlush] #2327953
06/28/17 10:28 AM
06/28/17 10:28 AM
Indianapolis, IN
B5Cuda440-6 Offline
B5Cuda440-6  Offline
Indianapolis, IN
iagree
Use Brad Penn, it is semi-synthetic and has higher Zinc content for flat tappet cams.
Re: Synthetic oil or not? [Re: gregok] #2328572
06/29/17 01:41 PM
06/29/17 01:41 PM
Chicago
PurpleBeeper Online content
PurpleBeeper  Online Content
Chicago
Synthetic lasts longer between oil changes....if you are a "maintenance super hero", there's no need for it. I pulled apart my original Mustang motor after 250,000 miles, running only the cheapest conventional oil (using police/severe duty maintenance schedule) and it looked like you could eat off of it...no sludge whatsoever. High zinc (as found in high mileage oils) is a good idea for cars without catalytic converters.
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
