Re: New Oil Thread Four Stroke Motorcycle Oil?
[Re: dogdays]
#2328143
06/28/17 05:07 PM
06/28/17 05:07 PM
RapidRobert
Another avenue for oil with a sufficient amount of anti-wear compounds is four stroke motorcycle oil. but I can buy Valvoline 4 stroke motorcycle oil which has zinc/phosphorus concentrations of around 1100. A quart is $4.69 locally. I don't know what the other additives for motorcycle oil do in a 440. Maybe someone else does. Experts? I heard that too way back. Sounds good so far (enough zinc/good price). I'm thinking that the guys at www.mototuneusa.com that published "breakin secrets" a VG informative guide on ring breakin that applies to our engines would know (or some other biker sites) if there are any caveats that might be a problem for us.
[Re: RapidRobert]
#2328150
06/28/17 05:28 PM
06/28/17 05:28 PM
Posts: 20,500 Eagle, Idaho
Neil
The Doctor is in.
The Doctor is in.
Eagle, Idaho
Oil change intervals on dirt bikes seemed very high when I used to ride a few years ago. I would wonder more about how long it would last than if it was capable enough to do the job.
I used either Honda oil or Maxima. The later has been around a long time and has an excellent reputation.
[Re: A727Tflite]
#2328372
06/29/17 12:30 AM
06/29/17 12:30 AM
Posts: 8,020 Pangaea
B5 Bee
Pangaea
You mean JASO - not JATO - correct ? Yes, JASO, not JATO A JATO is Jet Assisted Take Off rocket!
[Re: dogdays]
#2328392
06/29/17 01:06 AM
06/29/17 01:06 AM
Posts: 20,751 A collage of whims
topside
A collage of whims
Not sure if you're planning to use the oil in a motorcycle or car, but: Yamalube has a really long warranty - longer than any motorcycle - but for their "dino" oils, change intervals are frequent, measured in hours; synthetics can run longer. Not really news, I know. Yamalube runs $8.99/quart for their cheapest 10W40. Not a bargain. For whatever it's worth, the fuel filters on cars are bigger than most MC oil filters, but then of course they carry less oil. Maybe there's some relationship between filtering & change intervals. Obviously some MC oils have to work with wet clutches, so I'd guess their additive packages differ from automotive/truck oils. I'd guess that's the difference with V-twin oils, which probably also need to cushion better, judging by their heavier viscosity.
[Re: dogdays]
#2328506
06/29/17 11:22 AM
06/29/17 11:22 AM
DaytonaTurbo
Manitoba, Canada
Why keep beating a dead horse? Several of the oil companies manufacture oil specifically for our old flat tappet engines. Watch out with the new shell rotella oils, the CK-4 rated oils are limited to around 1000-1100ppm of zinc. Some of them are CK-4/SN rated and those are 800ppm. I like amsoil but there's plenty of other companies in the game. Amsoil's break-in oil has 2265 zinc. Their Z-Rod oil made for our old cars is SL rated and 1440 zinc with an extra additive package or corrosion control during long-term storage. Their dominator racing oil lists over 1500 zinc and isn't even API rated at all. For the one oil change per year I do on my old cars, IMO it's not worth cheaping out and worrying about what I can get at walmart. https://www.amsoil.com/techservicesbulletin/MotorOil/TSB%20MO-2007-08-08%20Flat%20Tappet.pdf
[Re: 71birdJ68]
#2328597
06/29/17 02:38 PM
06/29/17 02:38 PM
Posts: 9,066 Eugene, Oregon
minivan
Eugene, Oregon
Mobil 1 has two oils for bikes, one for V twins, and the one I use for real motorcycles that have a wet clutch. Do you mean the bikes that have a separate area and use a specific oil for the clutch? OR the bikes that use the same dirty oil the engine contaminates??
