Re: holley 80457-11 stumble
[Re: montanamopar92]
#2328137
06/28/17 05:00 PM
06/28/17 05:00 PM
RapidRobert
float level good? AP tip in is immediate/duration of squirt is good? no vac leak? what is the initial? how mild is the cam? might need more initial. The stumble is taking off from a stoplight real easy or is it with medium throttle or? EDIT ported or manifold? what carb? MORE EDIT I see the carb in the thread title.
#2328278
06/28/17 09:47 PM
06/28/17 09:47 PM
RapidRobert
if ya just bump a gas a little it just bogs. is the stream immediate, I mean right when you bump it (you can check in your driveway).
#2328283
06/28/17 09:55 PM
06/28/17 09:55 PM
RapidRobert
when you're looking in the airhorn is the tip in immediate when you just barely jerk the throttle (as in a good squirt). Only 2 things going on when you jerk the throttle, temporary lean which the squirt overcomes and you lose vac (timing) from the can (way less likely an issue on that one).
#2328362
06/29/17 12:05 AM
06/29/17 12:05 AM
Posts: 2,499 God's Country Maryland
GODSCOUNTRY340
Your linkage needs to be touching the accelerator pump arm, it needs to be moving the instant the throttle moves or you'll get a bog. If this is already adjusted correctly, you need a larger squirter.
[Re: GODSCOUNTRY340]
#2328561
06/29/17 01:18 PM
06/29/17 01:18 PM
Posts: 632 MD-USA
Dodgeguy101
MD-USA
Your linkage needs to be touching the accelerator pump arm, it needs to be moving the instant the throttle moves or you'll get a bog. If this is already adjusted correctly, you need a larger squirter. I agree.
