Small block rocker arms #2327807
06/28/17 12:04 AM
06/28/17 12:04 AM
sioux falls, sd
10sec.dart Offline OP
sioux falls, sd
Why does nobody make a rocker over 1.6 for a la small block shaft mount??, I see they make bigger ones for magnums and w-stuff but why not for the factory style shaft mount?
Re: Small block rocker arms [Re: 10sec.dart] #2327813
06/28/17 12:14 AM
06/28/17 12:14 AM
The only way to get the true answer is to call the manufactures and ask them up scope
Let us know what you find out please so we can share that in the future thumbs
Re: Small block rocker arms [Re: 10sec.dart] #2327838
06/28/17 12:53 AM
06/28/17 12:53 AM
Washington
madscientist Offline
Washington
Because you can't really make the rocker any longer and you can only move the adjuster so close to the shaft before the adjuster is too close to the shaft.
IIRC Harland Sharp used to have a 1.65 rocker. Not sure if they still do.
Also IIRC T&D would do a 1.7 if you used the small diameter shaft.
But that would mean relying on my memory. I wouldn't do that.
Re: Small block rocker arms [Re: Cab_Burge] #2327840
06/28/17 12:53 AM
06/28/17 12:53 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Harlan Sharp has made special rockers for me with no issues and very quick too. Give them a call and ask for their mopar specialist
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Small block rocker arms [Re: 10sec.dart] #2327852
06/28/17 01:06 AM
06/28/17 01:06 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
My T&D's are 1.7 and I don't think it would be an issue getting 1.8's.
Re: Small block rocker arms [Re: justinp61] #2327866
06/28/17 01:47 AM
06/28/17 01:47 AM
Washington
Washington
Are they are Chrysler diameter shafts or on the smaller shafts?
Re: Small block rocker arms [Re: 10sec.dart] #2327917
06/28/17 08:32 AM
06/28/17 08:32 AM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
My Yella Terra's are shaft mounted 1.65's. These are rollers but they now make bushed units too.
YT6300: SB Chrys, Adjust, 1.65, Modular YT shafts/full bearings (shown in picture)
YT6011: SB Chrys, Adjust, 1.5, Uses factory shafts, Bronze bushed
YT6764: SB Chrys, Adjust, 1.65, Uses factory shafts, Bronze bushed (new)
Re: Small block rocker arms [Re: 10sec.dart] #2327933
06/28/17 09:59 AM
06/28/17 09:59 AM
bronx n.y
O
one bad fish Offline
O
bronx n.y
HARLAN SHARP MAKES CUSTOM ONES I HAD THEM MADE
Re: Small block rocker arms [Re: 10sec.dart] #2328066
06/28/17 02:05 PM
06/28/17 02:05 PM
Earth
Rob C Offline
Rob C  Offline
Earth
The Magnun rocker arms are a 1.6 to start with so looking for a 1.7 is easy but I have not noticed a 1.8 advertised for the Magnum head.
