Re: Small to big bolt pattern wheels
[Re: moparvinson]
#2327529
06/27/17 02:49 PM
06/27/17 02:49 PM
Posts: 74,976 U.S.S.A.
JohnRR
U.S.S.A.
Front brake assemblies , and rear axles ... depending on the rear you currently have.
[Re: moparvinson]
#2327541
06/27/17 03:09 PM
06/27/17 03:09 PM
Posts: 860 lancaster,california
johnnycuda
I used the spindles, brakes off a '73 Duster, had to change the flex brake line as well. For the rear, mine had a 8 3/4 already, used a set of C-body axles that had been cut down to A-body length ,(or you can get new axles from Yukon and a few others), I used the drum brakes and matching backing plates from a '66 B-body 8 3/4.
1970 'Cuda,Lime Light,499 Indy S/R's 10.70's @125,street driven ALOT! 1966 Barracuda 360,now a 5spd,Hemi Orange,Hot Rod Air, New daily driver-2003 Ram 2500 Cummins 5.9 '69 Valiant 2-dr, sleeper! New project---1938 Dodge truck, plan is a 360 with a A500, AC, Calvert rear susp., rack and pinion front with coils.
[Re: moparvinson]
#2327587
06/27/17 04:52 PM
06/27/17 04:52 PM
Posts: 16,844 Phoenix - surface of the sun
nomore65BelvJim
73 up A bodies COULD have large bolt pattern. Drum brake front=small bolt pattern. 73-up Disc front=large bolt pattern. 73 up A body 7.25 rear came with both bolt patterns. 73 up A body 8.25 rear was large bolt pattern only. If you have an 8.75 now I'd get new axles (Dr.Diff) and replace the rear brake assemblies with 10x2-1/2". Donor can be from almost any 65 up rear end EXCEPT a body small bolt rear end. You can also use the F,M,J disc brake assemblies for the front. Either way you'll need the large ball joint upper control arms or the adapters to use the small ball joint.
[Re: moparvinson]
#2327787
06/27/17 11:28 PM
06/27/17 11:28 PM
Posts: 5,102 Western Md.
skicker
"The Champ"
"The Champ"
Western Md.
Cut down a C body Housing to 8 3/4 A Body Specs. Call Cass and order a set of big bolt conversion axles for an A body 8 3/4. As noted above backing plates-drums from another 8 3/4 and your good. Don't try to use a stock width 65 B body rear under a 67-69 Dart...It's just too wide and doesn't fit worth a crap...
...FAFO...
[Re: moparvinson]
#2327829
06/28/17 12:42 AM
06/28/17 12:42 AM
RapidRobert
You have SBP drums front/rear. there would be enough meat on the front drums for sure & likely on the rear axle flanges to redrill em to 4&1/2" BBP if desired for screw in 1/2" threaded wheel studs, drilling on your drill press would be easy & tapping would be a bit harder to get the tap started straight. make a 4" and a 4&1/2" circle on a piece of stiff fiberboard or something similar then make a pinprick anywhere on the 4&1/2" circle then another mark in a straight tangent line 2.645" away from it then (3) more for (5) total & when done each dot should be 2.645" away from the next one. On the 4" circle make the dots 2.351", (5) of em. drill the 4" circle dots JUST to the dia of the 7/16 studs so you can slip the template snugly over the 7/16 studs to locate it firmly & with a pointed punch make (5) pinpoint marks on the drum/flange thru the template on your original pinprick marks on the 4.5 circle to locate the new holes on the drum/flange to be drilled for the 1/2" studs. the BBP wheels have a larger center register hole so you would need lug centric lug nuts to center the wheel. On the rear axle flanges there is the big hole for your socket/extension to tighten the axle flange nuts so you would want to clock the pattern to avoid any of your new 1/2 holes landing right by that hole. this plan might not be up your alley but it is an option but you would not need to buy any new parts to speak of. On the other options SBP and BBP 7&1/4 axles do not interchange from their respective 7&1/4 housings.
[Re: moparvinson]
#2327941
06/28/17 10:16 AM
06/28/17 10:16 AM
Posts: 6,095 Valencia, España
NachoRT74
Valencia, España
AALL 73 and lates A bodies got big bolt pattern
About rear axle. You can take any A body 8.75 rear end and get couple of any other body axle ( but A body ), remove the axle hubs from them and reinstall them on the A body axles from the full assembly rear end you got. I think that's way easier than mod a full rear end dimmensions.
This job has being done here with success even on 1/4 miles cars.
[Re: NachoRT74]
#2327945
06/28/17 10:21 AM
06/28/17 10:21 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Nope About rear axle. You can take any A body 8.75 rear end and get couple of any other body axle ( but A body ), remove the axle hubs from them and reinstall them on the A body axles from the full assembly rear end you got. I think that's way easier than mod a full rear end dimmensions.
There are zero other body axleshafts with the 4.5" bolt pattern that will swap in without mods and you cannot remove the axle hubs, it's a one piece axle. This job has being done here with success even on 1/4 miles cars.
Not thinking this is true either.
[Re: moparvinson]
#2327958
06/28/17 10:35 AM
06/28/17 10:35 AM
NachoRT74
Valencia, España
Ok, will tell is not posible to do it to couple of personal friends who already did it ( on a 70 Swinger and a 71 )
HEY GUYS! WHAT YOU ALREADY MADE IS NOT POSIBLE, GET IT BACK... WHAT ? DID YOU MAKE IT 8 YEARS AGO AND ARE USING IT ON THE TRACK SINCE THAT? WAIT! ITS IMPOSIBLE YOU MADE SOMETHING WRONG! GET IT BACK
LOL
Bud, trust me.
Even they seem to be, axles are not one piece
About all being 4.5"... I'm pretty sure they are since front discs become standard, but is true, can be wrong on that? And even still front drums were available, I think they become 4.5" too to get all standarized? Not sure
[Re: moparvinson]
#2327963
06/28/17 10:43 AM
06/28/17 10:43 AM
NachoRT74
Valencia, España
About the hub interchange... ask them by yourself if you want Can't find the way to get the link from the app at the iPad, but a screenshot with their FB ID can help if you want to try to contact them... the car is on front pic
[Re: NachoRT74]
#2327965
06/28/17 10:48 AM
06/28/17 10:48 AM
RapidRobert
yes '73-'76 A body front disc apps were all BBP (single piston calipers) but '73-76 A body front drum brake cars were still SBP, at least some were (I've had several). not sure if any 4 wheel drum 73-76 A setups were BBP.
[Re: moparx]
#2328005
06/28/17 11:57 AM
06/28/17 11:57 AM
Posts: 20,159 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I have all aftermarket stuff on my cars but if I didn't I would go with this set-up on the fronts if I wanted 4 1/2 inch bolt pattern. http://www.forabodiesonly.com/mopar/threads/using-mustang-rotors-for-4-5-bc.20544/
[Re: moparx]
#2328034
06/28/17 12:42 PM
06/28/17 12:42 PM
NachoRT74
Valencia, España
That's what my friends didn't want, deal with redrilling process and precision on the job, plus maybe get some weakness on hub. They already had some old damaged B body 8.75 axles around and the car came equipped with 8.75, so interchanged the hubs and done. Need of course to be at a machine shop... press, weld, machine however not really precission... but way easier than make the same job, plus precisision on a full axle assembly. yes '73-'76 A body front disc apps were all BBP (single piston calipers) but '73-76 A body front drum brake cars were still SBP, at least some were (I've had several). not sure if any 4 wheel drum 73-76 A setups were BBP. disc only were 4 1/2". drum brakes were ALL 4" bolt pattern. those cars were relatively new back when i owned a junk yard. we had hundreds of then through during 72-84 and ALL the A body drum cars to '76 were 4" bolt pattern. Got it!
[Re: NachoRT74]
#2328229
06/28/17 08:04 PM
06/28/17 08:04 PM
Supercuda
About to go away
About to go away
up yours
I do not need to trust you. All A bodies got one piece axleshafts on all axles. You got a two piece one you need to show us.
[Re: moparvinson]
#2328244
06/28/17 08:28 PM
06/28/17 08:28 PM
RapidRobert
what about using the bolt pattern adapter plates? I used em on a dart DD & no issues. You have a 7&1/4 so it is a low po deal & they'd be a bolt on & go deal for you but would add a bit of side width. I did check torque regularly as a precaution since it was my first time useing em & I heard a few caveats but they stayed tight zero issues.
