car body dolly wheels ?? #2327399
06/27/17 05:06 AM
06/27/17 05:06 AM
Oh
His and Her 69's Offline OP
Oh
I am getting ready to take the suspension out from under my 69 RR
and I am looking for ideas on how to move it around in my stone driveway easily. I got some wheels from harbor freight and they are not heavy duty enough, 300 lbs cap each, and they are half flat with max air pressure with the car weight on them. I don't think small wheels would work well enough in the stones.
I have brackets made for both ends of the car that bolt to the bumper bracket locations. They have a 4" square flat steel plate welded to u channel steel and flat plates where the bumper bolts go thru. Not looking to spend 500. to buy the US car tool ones.
Any home made ideas for some or wheels that will hold the cars weight that I can attach to my already made brackets ???
Any Ideas or Help is Appreciated.
David
Re: car body dolly wheels ?? [Re: His and Her 69's] #2327441
06/27/17 11:09 AM
06/27/17 11:09 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
You may want to consider scaffold casters.
Scaffold Caster
Re: car body dolly wheels ?? [Re: His and Her 69's] #2327449
06/27/17 11:23 AM
06/27/17 11:23 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
The taller the wheel, the better. Any pneumatic caster shorter than 16" won't take any weight AND I've never seen one that holds air for more than a day!! Scaffold casters can be a problem to mount since they have a post instead of a plate. For the same money you can find a good 6" or 8" urethane caster with a cast hub rated around 800 pounds each.
Re: car body dolly wheels ?? [Re: His and Her 69's] #2327450
06/27/17 11:26 AM
06/27/17 11:26 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Also, I wouldn't bolt to the bumper bracket at the rear - that's too far back (in my opinion) and can induce sagging. The rears should be mounted at the front spring hanger brackets.
Re: car body dolly wheels ?? [Re: His and Her 69's] #2327451
06/27/17 11:29 AM
06/27/17 11:29 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
This is how I know pneumatics are not a good choice ...
Re: car body dolly wheels ?? [Re: His and Her 69's] #2327673
06/27/17 07:50 PM
06/27/17 07:50 PM
Washington/Las Vegas
1971 Gran Coupe Offline
Here is what I am doing for a cart. I used some scaffold wheels and had some heavy wall pipe and came up with this design. You definitely want to have brakes on the wheels. I will install some pipe clamps to secure the frame to the cart which will make it easy to roll outside too. I ran a 2x6 and 2x8 on the frame, making it easy to shim the body if needed when metal install starts. This moves around real easy and is extremely solid. Still have the ability to use jack stands on the rails when needed.
Re: car body dolly wheels ?? [Re: His and Her 69's] #2327699
06/27/17 08:58 PM
06/27/17 08:58 PM
jersey shore
flypaper Offline
I hate Texas
flypaper  Offline
I hate Texas
jersey shore
good to know about the pneumatic tires.
i was about to buy some myself from northern tool.
the rigid casters do not work at all once you are off of concrete or asphalt.
hmm
i might have to figure a way to modify a small trailer tire
or something else now...
Re: car body dolly wheels ?? [Re: His and Her 69's] #2327715
06/27/17 09:43 PM
06/27/17 09:43 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
1971 Gran Coupe
Just my 2 cents ... the wheelbase on your cart is too short and will be unstable - a real hazard if you're pushing the car and a wheel catches a piece of gravel or something. If you could lengthen the wheelbase and then secure the car to it you'd be a lot better off.
Re: car body dolly wheels ?? [Re: flypaper] #2327719
06/27/17 09:48 PM
06/27/17 09:48 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
I bought mine from House of Wheels as I used to work next door to them many years ago. I ended up with some large diameter black urethane ones that are rated for like 1200 lbs ea. They roll around pretty easy over concrete joints etc. Big wheels are key if you want the car to travel any real distance over anything not level.
http://www.howi.com/store/casters/
Re: car body dolly wheels ?? [Re: Neil] #2327740
06/27/17 10:14 PM
06/27/17 10:14 PM
New Mexico
JMCFAN Offline
JMCFAN  Offline
New Mexico
Those look like nice ones! I ordered my set from Autotwirller.. money well spent. I am still moving mine around with engine and trans installed.. but its heavy. takes 2 to maneuver it..and just slightly...I am close
68 Charger 383/ AT Green/Green VT
70 Roadrunner 383/4sp Purple/Black VT
Re: car body dolly wheels ?? [Re: JMCFAN] #2327879
06/28/17 02:22 AM
06/28/17 02:22 AM
Mid Michigan
Mr. Smurf Offline
Mr. Smurf  Offline
Mid Michigan
I made one for A bodies, 6" casters, the support pads with locating pins fit the transfer holes in the front & rear subframes.
It supports the car the same way ma mopar did when it was built.
Ed
Re: car body dolly wheels ?? [Re: Mr. Smurf] #2327900
06/28/17 04:53 AM
06/28/17 04:53 AM
Oh
Oh
I have looked at most of the caster wheels and wasn't sure they would work going thru my stone driveway. Now in the garage on concrete I am sure most casters would work fine.
I need to do more research as I don't want to spend anymore money on ones that don't work. The pneumatic tires definitely won't work. I may swap the rear supports to the spring hanger.
I am just using them to take the car to the blaster and then when I get it home they will be removed since the car doesn't need any floor repairs, just primed and painted.
It's Nice to have a southern car to work on for a change.
Anymore thoughts will be Appreciated.
Thanks David
Re: car body dolly wheels ?? [Re: His and Her 69's] #2327939
06/28/17 10:13 AM
06/28/17 10:13 AM
moparx Offline
moparx  Offline
one thought that MAY work, although i have never used it for a body dolly. i once used 4, short 14" doughnut spares with the matching rear hubs from a couple of minivans to roll around a big truck frame outside in the junk yard. to swivel the front pair, i cut the legs off a pair of big swivel casters and welded them to the legs that were fabbed from 2"x 1/4" angle iron and welded to the minivan hubs. it worked great rolling over rocks and ruts in the yard, plus it was built to get the frame at a comfortable working height. i wished i had pics, but at the time, it didn't seem necessary.
beer
Re: car body dolly wheels ?? [Re: moparx] #2328120
06/28/17 04:18 PM
06/28/17 04:18 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
Its been the early 90's but I found urethane wheels at a local distributor for under $10 bucks each when they were selling at the local Fastener store for over $90 each..
Look around for a wholesaler..
Probably too small of a pic to see them on my rotisserie..
Re: car body dolly wheels ?? [Re: His and Her 69's] #2328193
06/28/17 07:15 PM
06/28/17 07:15 PM
jersey shore
flypaper Offline
I hate Texas
flypaper  Offline
I hate Texas
jersey shore
I'm glad i saw this thread as i was planning to
buy pneumatic tires myself as i have 2 garages and good size distance between them over gravel,dirt and a lawn.
its not going to happen with the rigid casters i do have.
Re: car body dolly wheels ?? [Re: flypaper] #2328263
06/28/17 09:08 PM
06/28/17 09:08 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Put down some plywood sheets, or 2x wood, and make tracks to and from for the car to roll on.
Move car.
Stop.
Reposition wood.
Move car again.
Repeat.....
Re: car body dolly wheels ?? [Re: His and Her 69's] #2328296
06/28/17 10:16 PM
06/28/17 10:16 PM
jersey shore
flypaper Offline
I hate Texas
flypaper  Offline
I hate Texas
jersey shore
that is how i do it now with plywood and it is a pita..
Re: car body dolly wheels ?? [Re: Stanton] #2328340
06/28/17 11:25 PM
06/28/17 11:25 PM
Wills Point, Texas
Hugh Jorgan Online work
Hugh Jorgan  Online Work
Wills Point, Texas
You can get a solid version of that pneumatic tire at Harbor Freight.
Re: car body dolly wheels ?? [Re: Hugh Jorgan] #2328455
06/29/17 04:44 AM
06/29/17 04:44 AM
Oh
Oh
All the ones I seen at harbor Freight had a Low weight rating, like 300 lbs. A bare shell is a good amount more then 1200 lbs.
I think I need something around the 2000 lb range.
I would like something in the 500 to 600 lb each rating and that would make me feel better.
I will get more time to surf tomorrow night and see what I can find. Maybe I should just pour a concrete driveway ?? LOL
I wish I could or even blacktop would be good.
Thanks, David
Re: car body dolly wheels ?? [Re: His and Her 69's] #2329266
06/30/17 07:22 PM
06/30/17 07:22 PM
Tucson, AZ
cruzin Offline
cruzin  Offline
Tucson, AZ
These worked well for me.
