valve body #2327085
06/26/17 06:54 PM
06/26/17 06:54 PM
SW FLORIDA
MPRB Offline OP
MPRB  Offline OP
SW FLORIDA
Hi
Is a 904 and 727 non lock up valve body the same?
Re: valve body [Re: MPRB] #2327113
06/26/17 07:59 PM
06/26/17 07:59 PM
Welcome here. I do not know but the tranny guys will. which trans do you have & are you missing the VB (or its damaged)?
Re: valve body [Re: MPRB] #2327115
06/26/17 08:07 PM
06/26/17 08:07 PM
SW FLORIDA
MPRB Offline OP
MPRB  Offline OP
SW FLORIDA
I need to service the one in my ride it is a 727 I have a old valve body I think it was from a 904 I am installing a shift kit and thinking of using the spare valve body so it will be ready to go when it's time
Re: valve body [Re: MPRB] #2327116
06/26/17 08:13 PM
06/26/17 08:13 PM
owasso ok
V
vindicator Offline
vindicator  Offline
V
owasso ok
The valve bodies are the same. There are two things that are different, one is the park pawl rod which you can easily switch and then there is one hold down bolt that should have a slotted hole so that it will work in either transmission.
Re: valve body [Re: vindicator] #2327125
06/26/17 08:27 PM
06/26/17 08:27 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The rear center hold down bolt hole is slotted in the aluminum casting but the steel separator plate has the hole located at one end of the slot for the 904 and the other end of the slot on the 727. This prevents them from being interchangeable without elongating the hole or installing an aftermarket separator plate with a slotted hole.
