67 Coronet R/T 4-speed thump from rearend when shifting? #2326841
06/26/17 10:49 AM
06/26/17 10:49 AM
Poland, Ohio 44514
captainjack Offline OP
Poland, Ohio 44514
I have a 67 Dodge Coronet R/T 4-speed and am experiencing a THUMP when releasing the clutch fromn first to second and second to third. Anyone
have any idea's on cause. Any info appreciated. I am original owner. Car has 50,683 miles. PM me or e mail moparjack67@sbcglobal.net. THANKS for the add MOPARTS!
Re: 67 Coronet R/T 4-speed thump from rearend when shifting? [Re: captainjack] #2326846
06/26/17 10:53 AM
06/26/17 10:53 AM
Az
69hemibeep Online content
69hemibeep  Online Content
Az
Pinion snubber hitting the floor? Do you have an extended snubber?
1969 Hemi Roadrunner 2nd owner
Re: 67 Coronet R/T 4-speed thump from rearend when shifting? [Re: 69hemibeep] #2326856
06/26/17 11:08 AM
06/26/17 11:08 AM
Poland, Ohio 44514
Poland, Ohio 44514
No the snubber I have is the Original that came with the car.
Re: 67 Coronet R/T 4-speed thump from rearend when shifting? [Re: captainjack] #2326930
06/26/17 01:22 PM
06/26/17 01:22 PM
Seattle WA
RichV Offline
RichV  Offline
Seattle WA
I have seen later model cars do this when they have a lot of backlash in the rear diff. It is annoying but it didn't affect durability.
Re: 67 Coronet R/T 4-speed thump from rearend when shifting? [Re: RichV] #2326933
06/26/17 01:27 PM
06/26/17 01:27 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Other possibilities are U-joints, trans mount, shocks / bushings, exhaust hangars weak. shruggy beer
Re: 67 Coronet R/T 4-speed thump from rearend when shifting? [Re: captainjack] #2326948
06/26/17 01:44 PM
06/26/17 01:44 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Are the rear springs sagging, rear ride height low? That will put the stock pinion snubber close to the floor.
Re: 67 Coronet R/T 4-speed thump from rearend when shifting? [Re: captainjack] #2327383
06/27/17 03:03 AM
06/27/17 03:03 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
I've had a few 8 3/4 center sections that the cross pin that retains the spider gears had started wearing a slot in the center's hub, one was about a 1/2" from ripping the hub into two pieces.
With the rear end jacked up and the tires off the ground, there was a very noticeable lack of movement between the driveshaft yoke and the tires when rotating by hand and changing rotation direction.
Check the noise out, don't assume everything is OK. Gene
