1995 auto Trans not shifting into 3rd.
#2326466
06/25/17 03:44 PM
06/25/17 03:44 PM
Posts: 3,136 Palm Coast, FL (near Daytona B...
Blown_Hemi
Just picked up a 2500 Cummins and it will not shift into 3rd. I can lift off the throttle and it will up shift but sometimes takes awhile. Any ideas?
Ask me my opinion of Frank Mitchell....... A Mopar crook!
Re: 1995 auto Trans not shifting into 3rd.
[Re: J_BODY]
#2326769
06/26/17 04:24 AM
06/26/17 04:24 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
front clutch piston seals is the first thing that comes to mind. Same here. I remember some models we had updated front drum , piston and seals for that type of problem. But I dont remember which models and years it was as I would have to look it up but I do remember replacing them during the 90's on some for that problem when everything else was working correct. Reverse usually still worked ok since it runs with much higher pressure. Ron
[Re: A727Tflite]
#2327645
06/27/17 06:54 PM
06/27/17 06:54 PM
Blown_Hemi
Your description is not very clear or complete. Does it get third when you tip out of the throttle all the time but not when you are on the throttle? Or never gets third? Does it have reverse all the time? Or no reverse? If you have reverse and get third on tip out - check the throttle kick down cable for freeness. There should be a return spring from the throttle lever to a bracket at the trans end. Check and make sure this cable goes wide open then returns all the way forward before doing anything else. Shifts fine when cold, 1st, 2nd, 3rd, OD. When warm takes awhile and about 2500 rpms before it shifts to 3rd. Reverse is fine. If I lift off the throttle it usually go into 3rd. I will check the throttle cable. Yes, return spring is intact.
[Re: Blown_Hemi]
#2327654
06/27/17 07:11 PM
06/27/17 07:11 PM
Posts: 25,871 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Even though the front clutch is also used in Reverse, a strong Reverse is no proof that the clutch is good because the line pressure increases dramatically in Reverse; so a weak clutch will still appear to be OK in Reverse.
