Best Spark Plugs for 605 Hemi
#2326204
06/24/17 08:23 PM
06/24/17 08:23 PM
Posts: 562 Ohio
lockjaw-express
Ohio
All,
What spark plugs would you recommend for my 605 Aluminum Hemi, it has the Indy (race) 426-RA1 heads, 11:1 CR, 655 Lift w/272/280 Duration & R110. I also have the Holley HP ECU with MPFI Sequential, MSD Digital 6 Ignition, MSD Wires.
It is a Street/Strip car, but mostly street, 4.10 Gears, and not a highway car. The engine Dyno’ed at 950HP @ 6400 RPM with and 1150 CFM Demon Carb, and smaller -2 Intake.
I currently am running the Holley HP.
Any ideas would be of great help, and Thank you!
Regards, Mark
Re: Best Spark Plugs for 605 Hemi
[Re: lockjaw-express]
#2326210
06/24/17 08:34 PM
06/24/17 08:34 PM
Posts: 562 Ohio
lockjaw-express
Ohio
Hi Andy,
Do you have a NGK Plug Number? The reach is the same as an Edelbrock 440 performer RPM Heads.
Would you recommend an extended reach plug?
Thank you!
#2326236
06/24/17 10:48 PM
06/24/17 10:48 PM
Posts: 12,587 Great Neck,LI,new york
hemi-itis
I have used several "racing" plugs.Used to use champs all the time back in the day.I use the NGK at $20 A SET.Also installed sooty plugs that were from an overly rich condition and they came out and read accuratlely.
#2326367
06/25/17 12:10 PM
06/25/17 12:10 PM
hemi-itis
I can check the PN next time I'm down at the shop.The 8 heat range worked for that combo on pump gas.I suggest you determine which PN you need and get 3 sets with 3 heat ranges say like 7,8 & 9.Plug reading must be done by clicking off the ignition at WOT at least at the top of 2nd gear AT or 3rd ith manual. Making a pass at the track click off over the stripe at WOT.If you drive back to your pit it will nullify the plug reading.You would like the change in color on the strap to be at the elbow.
[Re: hemi-itis]
#2326445
06/25/17 03:03 PM
06/25/17 03:03 PM
Posts: 43,161 Bend,OR USA
Cab_Burge
I like to work on one circuit at a time on my carbs, idle first, then transition, then part throttle cruise and then squirter and WOT jetting for the best mph results at the track in the 1/4 mile OP, having a good wide ban on the car is a big help As far as spark plug heat range on your deal on pump gas I would try Champion RN9YC or RC9YC and in Autolite # 3924 or 3923
#2326847
06/26/17 10:54 AM
06/26/17 10:54 AM
Posts: 13,363 Marion, South Carolina [><]
an8sec70cuda
I use NGK R5671A-8 (4554) in my 11:1 pumpgas 572" hemi when I'm not using nitrous. I go one colder on the spray.
#2326934
06/26/17 01:30 PM
06/26/17 01:30 PM
an8sec70cuda
lockjaw...hope it works out for you!
thumper...nope, never ran anything but the -8s in it on motor. Hemis are supposed to be more forgiving on pump gas than a wedge. Never had any problems w/ fouling them out or anything and they seem to work fine. Never saw a need to change.
#2326949
06/26/17 01:44 PM
06/26/17 01:44 PM
Posts: 31,025 Oregon
AndyF
An8sec70cuda,
I was told that I need to use a Resistor plug because I have both an MSD Box, and Holley EFI.
I called the NGK number, and they recommended this plug: BKR6E/6962
It is a V-Power Nickel, that is Resistor. He told me that I could go one colder if this plug is too hot.
I ordered a set from Summit, and will let you know the results.
I have had good results in the past with BR8EGV plugs, but those were on smaller displacement engines. I may also try those as well at some point...
Mark Exactly what I thought they would recommend. #6 seems to work just fine with 11:1 compression and EFI since that is what most of the OEMs use. Like they say, if you see any issues at WOT you can always switch to a #7 plug but I don't think you'll have a problem as long as your EFI is dialed in.
[Re: Thumperdart]
#2327325
06/27/17 01:16 AM
06/27/17 01:16 AM
hemi-itis
Have you tried 7's w/that low compression or is the Hemi sensitive to where it needs the colder plug............ With the last 5 year go round, the #8 put the color change in a good spot on the strap.That was 7.4:1 CR and 12 lbs of boost,new pistons are 9:1 so it's back to the tuning thing............. Pump gas might be no more than 3 lbs.
[Re: hemi-itis]
#2327366
06/27/17 02:28 AM
06/27/17 02:28 AM
Cab_Burge
The last pump gas 10:71 blown street Hemi stroker motor 484 C.I.made 924 HP at 7300 RPM on CA pump swill with 7.0 lbs. of boost and 33 degrees total timing with two Carb. Shop blower Dominator carbs. I made it have 9.3 to 1 static compression ratio so we wouldn't have to run more boost and heat up the intake manifold temps. to make 900 + HP on 91 octane CA pump swill back in 2002 How much power can your chassis handle now
