BRC crankshafts #2326089
06/24/17 01:22 PM
06/24/17 01:22 PM
Ames, Iowa
LoneMopar Offline OP
Ames, Iowa
Trying to determine if my old BRC crankshaft is worth saving.
Anyone remember these? I can't find much info on them. Were these very high quality pieces?
Mine is stamped BRC 65004, 400X4150. It was .010/.010 and now has a rod journal that would need to be -.020, maybe mains also. Are .020 under performance bearings hard to find?
Re: BRC crankshafts [Re: LoneMopar] #2326098
06/24/17 01:48 PM
06/24/17 01:48 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: BRC crankshafts [Re: LoneMopar] #2326103
06/24/17 02:00 PM
06/24/17 02:00 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
I don't believe "BRC" cranks were Bryant cranks.
I seem to recall they were an outfit in Tn(Tennessee Engine Works), and at least for a period of time they were using forgings that were supposedly of European origin...... German I think.
They were supposed to be "good" cranks, but I had a customer that bought a 511 that had one in it, and from a journal fit and finish standpoint...... It really wasn't very good.
I shared shop space with another full service shop for a while, and the guy who did the crank grinding wasn't impressed at all with it.
It was 4.250 stroke with Mopar journals and I had it stroked to 4.375 with BBC journals, and built a 542 out of it.
572-13 heads, made about 830hp.
After a couple seasons it came back for freshening..... The crank was loaded with cracks.
We replaced it with an Eagle.
Ive never seen any .020 under race bearings for Mopars from FM or Clevite, but perhaps King has something.
Re: BRC crankshafts [Re: fast68plymouth] #2326108
06/24/17 02:12 PM
06/24/17 02:12 PM
PA.
"Little"John
"Little"John
PA.
I goggled it just to see what popped up. lol
A good crank grinder could tell you pretty quick with a few tests.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: BRC crankshafts [Re: LoneMopar] #2326122
06/24/17 03:05 PM
06/24/17 03:05 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
BRC is Brooks Racing Components. They made rods and cranks. The last time I saw their shop was in Cosby TN.
Nautilus Racing-
Re: BRC crankshafts [Re: LoneMopar] #2326143
06/24/17 04:21 PM
06/24/17 04:21 PM
So. Burlington, Vt.
So. Burlington, Vt.
From what little I could find digging around.....
It appears Tennessee Engine Works sold the BRC name and crank manufacturing to JVR industries, which filed for chapter 11 in Florida in 2004........ Which looked like it was denied in 2006.
The name "BCR performance" is still in Florida, but it seems they are basically a piston company now.
Re: BRC crankshafts [Re: LoneMopar] #2326153
06/24/17 05:06 PM
06/24/17 05:06 PM
How about having it offset ground to BB Chevy rod journal size (2.2000 and increase the stroke at the same time to around 4.250? I've had that done more than once with a 4.150 stroke crankshaft up scope I had one new crank offset ground like that to 4.300 stroke boogie
Re: BRC crankshafts [Re: LoneMopar] #2326262
06/25/17 12:11 AM
06/25/17 12:11 AM
Memphis TN
B1HEAD_USER Offline
B1HEAD_USER  Offline
Memphis TN
I had a 4.5 stroke BRC I bought new in 1996. I was not very impressed with the finish. That thing lasted about 300 passes and I don't run my stuff hard.
