Re: fuel injection problem - experts, need direction please [Re: moparx] #2325723
06/23/17 01:54 PM
06/23/17 01:54 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
The TPS going bad is VERY common on the system you have.
Re: fuel injection problem - experts, need direction please [Re: moparx] #2325780
06/23/17 03:37 PM
06/23/17 03:37 PM
IN
formerratman Offline
IN
As has been suggested a couple times, you need to unhook the IAC after the engine is at warm idle and take it for a drive. Although spark timing is a major player in idle control, I see no possibility of it giving an 1800 rpm hang on coast-down. Is there an EGR valve still in place on the engine? All the LS swaps I do get it deleted, but in the unlikely event it is still attached to the intake -but the exhaust side is open to atmosphere- it could be driven open and cause high idle.
Re: fuel injection problem - experts, need direction please [Re: formerratman] #2325844
06/23/17 06:23 PM
06/23/17 06:23 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Have you disconnected the batt yet to clear..
like in the older units
wave
Re: fuel injection problem - experts, need direction please [Re: MR_P_BODY] #2326055
06/24/17 11:32 AM
06/24/17 11:32 AM
moparx Offline OP
moparx  Offline OP
mr. P., battery has been disconnected several times with cables being touched to drain any residual "'lectric" from the computer's inner guts. also, we did unhook the IAC after warm up, but like the dumazzes we are, our biggest mistake was to NOT write the results down so we could refer back to the results. this weekend looks good weather wise now, but i'm not sure we can get the car out due to other projects [can you say "honey do"] being "suggested". as we are both retired, maybe we can get on it next week. as has been mentioned several times, the TPS has been looked at several times and run through it's range, both on and off the car, passing [in my opinion] both the voltage and ohm tests. next time out, a notebook will be in the tool bag with my OTC scan tool. maybe then, i can positively say what results we get with what is tried. oh, i forgot to mention until it was just brought up. this conversion is used with an eliminated EGR valve. i fabbed a block off plate to take it's place, so that is one item we don't have to concern ourselves with. you guys are really trying to help out, and of this, we are SUPER appreciative ! bow
beer
Re: fuel injection problem - experts, need direction please [Re: moparx] #2326062
06/24/17 11:49 AM
06/24/17 11:49 AM
MR_P_BODY Offline
MR_P_BODY  Offline
It really does sound like its a air issue..
like its getting air from somewhere.. I know
if I mess with the throttle(move the position
I have to re-zero the TPS in the ECU. not sure
why it wants to hold the revs up.. is it always
at 1800 revs(no variance)
wave
Re: fuel injection problem - experts, need direction please [Re: MR_P_BODY] #2326066
06/24/17 11:55 AM
06/24/17 11:55 AM
moparx Offline OP
moparx  Offline OP
it's always 1800rpm or above, going down the road. sitting still, you can rev it till it hits the limiter as many times as you want, and it returns to idle as it should every time. this is why it's so frustrating to figure out why this is acting the way it is, going down the road only !
beer
Re: fuel injection problem - experts, need direction please [Re: moparx] #2326068
06/24/17 12:00 PM
06/24/17 12:00 PM
MR_P_BODY Offline
MR_P_BODY  Offline
beer
Try throwing it in neutral when this happens
and see if it falls back to idle
wave
Re: fuel injection problem - experts, need direction please [Re: moparx] #2326070
06/24/17 12:04 PM
06/24/17 12:04 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
Check for gas residue in the MAP sensor. At 1,800 rpm, it might not be a throttle issue. Maybe the MAP is faulty causing a high timing advance condition. Check your coolant sensor also, if it dips cold momentarily, it might raise the idle speed thinking it needs to warm up some more.
[image][/image]
Re: fuel injection problem - experts, need direction please [Re: moparx] #2326473
06/25/17 03:54 PM
06/25/17 03:54 PM
Sac, CA, USA
N
ntstlgl1970 Offline
ntstlgl1970  Offline
N
Sac, CA, USA
If your system can datalog, maybe that will point you in the right direction. If not have a buddy watch a scan tool or your tuning program while you drive. That way hopefully you can determine if the computer is commanding the high idle (indicating a sensor problem) or not (indicating a mechanical problem). If you have a good DVOM, you can sweep the TPS and watch for spikes or dropouts. The computer can only "see" what is going on via the sensors and react accordingly. If the IAC motor checks ok, does the engine have a PCV system? Is the throttle bore clean? I've also seen PCV valves fail open before (as in the valve physically came apart), but that would be very unusual.
If you don't have a scan tool, you can pick up a code reader from your local parts store that will show stream data for around $60. This is assuming you have the standard OBD-II connector. I would think that you would want to monitor IAC counts, TPS voltage and Coolant Temp and see if there is a pattern.
Re: fuel injection problem - experts, need direction please [Re: MR_P_BODY] #2326589
06/25/17 08:53 PM
06/25/17 08:53 PM
langley b.c. canada
don miller Offline
don miller  Offline
langley b.c. canada
beer
wave
I think what Mike is getting at here is taking the ecm and all the sensors out of the equation-couldn't this be something as simple as a collapsed motor mount hanging the throttle linkage partially open. Have you tried pulling the gas pedal up when the engine speed isn't coming down?
Re: fuel injection problem - experts, need direction please [Re: don miller] #2327467
06/27/17 12:03 PM
06/27/17 12:03 PM
moparx Offline OP
moparx  Offline OP
this weekend was not conductive for any testing, as other items took up our time. mr. P asked about throwing into neutral, and this has been done, but the engine still continues at the rpm it was before doing this. we also checked for interference at the throttle cable causing issues, as well as motor mounts being a cause. all checked out as being in perfect condition. the next course needed as of now is to hook up my tool and observe just single components and sensors while going down the road, logging the results to see if something stands out, or comes to light. as i said previously, i just observed the circuits for a short time to see if they were operating correctly. the biggest mistake on my part was the fact i didn't log the results. this caused me to chase my tail, as there were so many things i tried i lost track. i KNOW BETTER, and it is now biting me where i can't bite.
beer
Re: fuel injection problem - experts, need direction please [Re: moparx] #2329498
07/01/17 03:51 AM
07/01/17 03:51 AM
Detroit, MI
CokeBottleKid Offline
Detroit, MI
As has been discussed, IAC related items, IAC itself or a TPS can cause issues like this. Sometimes there's an A/C input that can offset the IAC value to compensate for compressor load but that's probably unlikely. A data log would help alot, I'd log the TPS, maybe IAC duty cycle or commanded position (depending on style), MAF or MAP depending if it's speed density or not. Any throttle switches (if there are any). Maybe even look at the coolant temp sensor and IAT, those being out of range can cause certain functions to kick in.
Re: fuel injection problem - experts, need direction please [Re: CokeBottleKid] #2329526
07/01/17 10:01 AM
07/01/17 10:01 AM
moparx Offline OP
moparx  Offline OP
last night, we got a chance to look at things. it seems the MAP sensor wants to stay at 15-16hg, and the throttle position varies between 40-59%, even at idle. for some reason, the rpm at idle is a steady 650-700, yet at cruise, it jumps on my scanner between 164-1988. i know that is not correct because it is running very smooth. next up, the owner thought it might show something if it was watched from idle to shift point. and the driver side mount promptly destroyed itself ! so much for a little restraint. laugh2 now until the mount is replaced, i'll take the MAP sensor off and inspect the intake port and sensor for buildup, and check the TPS for ohm readings through out it's range. but the rpm back & forth at cruise when the car is running perfectly, does that put the computer at suspect, or something else ? my scanner perhaps ? i'll check the scanner on my caravan today or tomorrow to get a ruling on it, as i am familiar with that system far more than this GM conversion system.
beer
Re: fuel injection problem - experts, need direction please [Re: moparx] #2329651
07/01/17 12:13 PM
07/01/17 12:13 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
No matter what is giving the incorrect input value either the IAC has to be open further or the timing has to be higher. What does that data show?
Doug
Re: fuel injection problem - experts, need direction please [Re: moparx] #2329801
07/01/17 04:35 PM
07/01/17 04:35 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I would check and recheck all your grounds and power sources, the RPM moving around could be from electrical noise which will cause all kinds of problems.
68 Barracuda Formula S 340
Re: fuel injection problem - experts, need direction please [Re: moparx] #2329840
07/01/17 06:00 PM
07/01/17 06:00 PM
Sac, CA, USA
N
ntstlgl1970 Offline
ntstlgl1970  Offline
N
Sac, CA, USA
I agree with what bad340fish said, check your grounds and power sources using the voltage drop method. Too many times these problems are caused by bad power or ground connections
Re: fuel injection problem - experts, need direction please [Re: moparx] #2329886
07/01/17 07:43 PM
07/01/17 07:43 PM
sgcuda Offline
sgcuda  Offline
Why is your TPS showing 40-59% at idle. That value is completely out of the park. TPS voltage should be steady at idle since it is against the stop. The idle speed would be controlled by the IAC.
[image][/image]
Re: fuel injection problem - experts, need direction please [Re: sgcuda] #2336437
07/13/17 11:54 AM
07/13/17 11:54 AM
moparx Offline OP
moparx  Offline OP
agree completely with this ! as badfish and ntstlgl-'70 mentioned, my power and ground need checked, as the pickup points for these are the ciggy lighter, so that may be an issue.
the motor mounts have been replaced, but now it's raining all the time, plus there is the grass cutting between showers my buddy has to contend with. and in the meantime, when we have a few minutes during the rains, we just built a pair of front wheels for his '64 ford galaxy. that story is one for a sit down discussion ! laugh2 but we got them to .012 in both directions on the bead seats on one, and .017 on the other.
beer
