Re: possible to pick a trunk lock?
[Re: Adam71Charger]
#2326056
06/24/17 11:36 AM
06/24/17 11:36 AM
RapidRobert
pay you skinniest neighborhood kid a buck to squeeze thru the back seat area with a socket or if you pick it, cut down a hacksaw blade to make a thin strip & use it to hold the door open & exert a slight CW rotation on the cyl as you reach in with a thin pick & push up each of the 5 tumblers till they "catch" then you can rotate the cyl the rest of the way. it will take a fair amt of practice & I would get the skinny kid to take care of it first.
[Re: Adam71Charger]
#2326110
06/24/17 02:20 PM
06/24/17 02:20 PM
Posts: 1,306 Laveen, Arizona
GTSDart340
Laveen, Arizona
Just drill the pins out with a small bit and use a screwdriver.
1949 International KB-2 "Mater" - 302/T5
1968 Dodge Dart GTS "The Drat" - 340/727
2006 Dodge Magnum R/T - Hemi
2016 Dodge Durango Limited - 3.6
[Re: GTSDart340]
#2326111
06/24/17 02:29 PM
06/24/17 02:29 PM
Posts: 36,840 South San Francisco, Californi...
MidPenMopar
Looking for fun? Keep looking
Just drill the pins out with a small bit and use a screwdriver. That's the way i did it when my road runner's trunk latch cylinder broke and would just spin. Of course the trunk was inaccessible from the rear seats due to the sub woofers so that was the only way in. It worked!
[Re: Adam71Charger]
#2326229
06/24/17 10:16 PM
06/24/17 10:16 PM
Posts: 1,272 Northern Calyfornua
Sxrxrnr
Northern Calyfornua
Once had a father in law who was a locksmith. Would go with him on some lock out service calls This was in 60's. GM cars he had a key ring with a very large number of keys that he would try until one would be jackpot. Somewhat forget what he did with Fords,,,,perhaps the owners if locked out were not interested to pay to gain entrance and just walk away from them.
Mopar's he would insert a blank key, twist and shake it about to make slight impressions on it, remove it, file impressions a bit and try again until lock opened.
He called it to impression the key. Always worked, but he preferred locked out GM's.
[Re: Sxrxrnr]
#2326239
06/24/17 10:58 PM
06/24/17 10:58 PM
Posts: 3,461 Dandridge TN
Dabee
Dandridge TN
On a road trip from Detroit to Reno for Hot August Nites in my 69 Bee. We stopped in Iowa for the night. Next morning I'm in the shower, the girl friend thinking she's helping out puts my dirty pants in the dirty laundry bag and puts it in the trunk, which was open, the car doors were locked, closes the trunk. I get out of the shower look for my dirty pants to get the keys and wallet, no pants. I ask her were my pants are, she says in the trunk. Call a local lock smith to come out and open the trunk. He used the impression the key trick. Took him about ten minutes.
[Re: cudaman1969]
#2326345
06/25/17 10:46 AM
06/25/17 10:46 AM
RapidRobert
I get a good one and change the pins to fit the key. Don't even need all five pins, two or three will work. Agreed, no one picks locks anymore (except in the movies). several junk cyls to choose from is handy so you can select the tumblers to match the key notch depth(s). You want the heights "even" with the key inserted. the tabs on the chrome cover are delicate so bend them just enough so the cover will come off. & there is a specific graphite lube to squirt in there available at your parts house but it ain't absolutely neccessary.
[Re: 62maxwgn]
#2326424
06/25/17 01:45 PM
06/25/17 01:45 PM
Posts: 32,985 Grand Prairie,Texas
stumpy
Grand Prairie,Texas
Taping a thin blade screwdriver to a broom handle works great if you can get the back seat out.
Barry,just had to respond to this,couldn't help myself !! If the trunk lock arm is engaged in the latch,how would you ever get a thin blade screw driver on a broom handle in from the other side ? The lock arm isn't that tight a fit. There is room to get a thin screwdriver in between the arm and the latch. Give it a try.
