Got a sweet deal on a front axle #2324507
06/21/17 01:36 AM
06/21/17 01:36 AM
Wisconsin USA
themoparmanjc Offline OP
Wisconsin USA
Dana 60 kingpin out of 91 cummins for 200 bucks. Getting the np 205 from the same truck this weekend for 300. Both are going in my 85 W350, which came stock with Dana 44 front.
Don’t Buy From Famous Bob AKA Bob McCarty in Oklahoma. He is a Crook!
Re: Got a sweet deal on a front axle [Re: themoparmanjc] #2324508
06/21/17 01:37 AM
06/21/17 01:37 AM
Wisconsin USA
Wisconsin USA
A pic of my 85
Re: Got a sweet deal on a front axle [Re: themoparmanjc] #2324749
06/21/17 02:51 PM
06/21/17 02:51 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Are you sure they're 60 and not 61? What ratio currently in them?
You might be stuck with 3.07 gears...
Angry white pureblood male
Re: Got a sweet deal on a front axle [Re: ruderunner] #2324766
06/21/17 03:11 PM
06/21/17 03:11 PM
Wisconsin USA
Wisconsin USA
Nope. My original rear is a 4.10 d60. Original front is d44. Front I just bought has 60 f cast into it with a tag that says 4.10.
Re: Got a sweet deal on a front axle [Re: themoparmanjc] #2325110
06/22/17 07:36 AM
06/22/17 07:36 AM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Just wanted to let you know since lots of the early diesel trucks had an odd ball 61 front axle.
Sounds like you scored here.
Re: Got a sweet deal on a front axle [Re: ruderunner] #2325243
06/22/17 02:42 PM
06/22/17 02:42 PM
Guitar Jones Offline
If it had the 727 trans. The stick trucks got either 3.54 or 4.10.
Re: Got a sweet deal on a front axle [Re: themoparmanjc] #2326032
06/24/17 09:24 AM
06/24/17 09:24 AM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Exactly. 91 was a split year with early trucks having the 727, late trucks getting the 518. With the 518 then 3.54 and 4.10 were available.
Stick always had the better gearing.
