What is the differance 1967-1969 b-body disc and c-body #232585
02/22/09 03:10 PM
02/22/09 03:10 PM
ny
brokethebank Offline OP
ny
Is there a differance between the whole assembly.I need a set for a Hemi car.Someone changed over to drum probably because they couldnt get parts?My car is a 1968.
Re: What is the differance 1967-1969 b-body disc and c-body [Re: brokethebank] #232586
02/22/09 03:13 PM
02/22/09 03:13 PM
Dreaming of the 808
AZ_A12_BEE Offline
AZ_A12_BEE  Offline
Dreaming of the 808
None of the C body stuff will work, you need 67-69 B body parts. Not all hemi cars got discs, are you sure your car originally had them?
69.5 A12 Bee, first purchased in 1976, car 169 on registry 69 Coronet R/T 440/4 spd 69 Coronet 500 Conv H code 383 4bbl/auto 37 Plymouth PU Find your spot on earth and ride it.
Re: What is the differance 1967-1969 b-body disc and c-body [Re: brokethebank] #232587
02/22/09 03:43 PM
02/22/09 03:43 PM
MOPAR HEADQUARTERS IN ALDEN NY
hemigod426 Offline
hemigod426  Offline
holy crap johnny cake lives///// hows things? where you sniffin starting fluid again. c-body is 12 inch rotors and bigger splindle and caliper in four piston years. later 11.75 c-body parts will fit with single pistons. four piston hemi brakes are 1966-69 b-body only with two part rotors.
MOPAR OR NO CAR
