Oil cooler kits #2325555
06/23/17 01:26 AM
06/23/17 01:26 AM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
Can anyone suggest a good quality oil cooler kit for mopar? There are a few on ebay, but not sure of the quality.
Re: Oil cooler kits [Re: mopar dave] #2325569
06/23/17 02:08 AM
06/23/17 02:08 AM
Mt Morris Michigan
Mt Morris Michigan
Heres an ebay special for $156. Quality unknown.
Re: Oil cooler kits [Re: mopar dave] #2325605
06/23/17 07:36 AM
06/23/17 07:36 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
have you checked your running oil temp to confirm you need an oil cooler?
Re: Oil cooler kits [Re: rebel] #2325625
06/23/17 09:19 AM
06/23/17 09:19 AM
Mt Morris Michigan
Mt Morris Michigan
No, but its very likely. So just getting it nailed down when the time comes to order one. Looks like it will be better to buy in individual parts instead of kit form to get quality parts and not going broke.
Re: Oil cooler kits [Re: mopar dave] #2325626
06/23/17 09:22 AM
06/23/17 09:22 AM
Mt Morris Michigan
Mt Morris Michigan
Setrab seems to be a quality cooler and the filter adaptor sandwich is available with thermostat which i believe to be a plus.
Re: Oil cooler kits [Re: mopar dave] #2325763
06/23/17 03:08 PM
06/23/17 03:08 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
The downside of the cheap adapters is A- they are cast, not billet or forged. B- the openings are -10 but the passages neck down to 3/8 (-8), too small IMHO. Earl's makes one that is thermostatic and billet but goes for over 100 usd on Summit.
Re: Oil cooler kits [Re: Skeptic] #2325793
06/23/17 04:08 PM
06/23/17 04:08 PM
Mt Morris Michigan
Mt Morris Michigan
thanks for that info. didnt know that. theres a bunch of different adaptors on summits site. B&M has a nice cooler as well.
Re: Oil cooler kits [Re: mopar dave] #2325808
06/23/17 04:46 PM
06/23/17 04:46 PM
New York
polyspheric Offline
polyspheric  Offline
New York
X2 - buy a quality adapter, and then port the passages and intersections with a small carbide in a Dremel. You'd be amazed at how crude even the best ones are.
It's so easy: look for sharp edges at the corner of 2 passages, a passage into a cavity, etc. and just add a clean radius, even 1/8" helps.
The longer the lines, the bigger the fittings and hoses must be. Too big is harmless.
Boffin Emeritus
Re: Oil cooler kits [Re: polyspheric] #2325933
06/23/17 10:27 PM
06/23/17 10:27 PM
Mt Morris Michigan
Mt Morris Michigan
it will be mounted in front of radiator,so maybe 3-4' hoses.
