Re: AJ..have they found something?
[Re: A/MP]
#2325112
06/22/17 08:04 AM
06/22/17 08:04 AM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
Just remember, NHRA had Warren Johnson spec out the pro stock motors for GM, Ford and Chrysler. Since he did the building for himself and other GM racers, its pretty simple to see why GM had a better cylinder head.That's where all the power is. That's the first I've read about this. Any links?
[Re: justinp61]
#2325117
06/22/17 08:40 AM
06/22/17 08:40 AM
Posts: 3,696 jersey
Spaceman Spiff
jersey
Google " Warren Johnson DRCE"
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
[Re: cmansell]
#2325124
06/22/17 09:21 AM
06/22/17 09:21 AM
Posts: 2,933 Finalnd, Perkele
jyrki
Finalnd, Perkele
That's in some history book. Nothing to do with the PS engines of today. When the 500 cu in rule without weight breaks came out, I thought a Hemi might do well. It didn't. The GM engines developed quickly, especially the top block. They were first based on regular head castings that were radically changed. What the first DRCE's did, was basically making all the changes so far in to "as cast" versions.
Plynouth VIP '67 TT IC EFI
[Re: cmansell]
#2325221
06/22/17 01:55 PM
06/22/17 01:55 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
Et is looking better, but the mph seems to be up. Anyone in the know if they have changed something or just hard work paying off? They now are using CFE ported heads and intakes.
[Re: cmansell]
#2325234
06/22/17 02:16 PM
06/22/17 02:16 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Does he get a higher rpm limit?
Mopar to the bone!!!
[Re: cmansell]
#2325581
06/23/17 03:19 AM
06/23/17 03:19 AM
Posts: 20,201 Park Forest, IL
slantzilla
Park Forest, IL
Rumor has it that Westcott will be at Norwalk too.
[Re: slantzilla]
#2325586
06/23/17 03:33 AM
06/23/17 03:33 AM
Posts: 43,263 Bend,OR USA
Cab_Burge
Rumor has it that Westcott will be at Norwalk too. Is he still trying to race a Ford in Pro stock or has he gone back to his Chevy roots?
[Re: Dave Hall]
#2325622
06/23/17 09:03 AM
06/23/17 09:03 AM
Posts: 20,655 in a cattle trailer down by th...
Guitar Jones
Sure hasn't helped his reaction times...
[Re: Guitar Jones]
#2325630
06/23/17 09:33 AM
06/23/17 09:33 AM
Posts: 20,195 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Sure hasn't helped his reaction times... AJ played his stupid little staging game AGAIN and it bit him in the azz AGAIN!!!!!!!!!! Like it always does.
[Re: cmansell]
#2325680
06/23/17 11:49 AM
06/23/17 11:49 AM
Posts: 19,379 Las Vegas
Al_Alguire
Las Vegas
They are all with the symmetrical port head now. It simply makes more power under the new rules. AJ an other Mopar teams got caught with their pants down when the RPM limit came in. The symmetrical port stuff got put on the back burner as it was down on power to the asymmetric stuff under the old rules so development stopped on the symmetrical head. They are all playing catch up now. McGaha and team stayed with the symmetrical port stuff from the get go, the reason he ran so poor when in a Dodge. But that info paid off in sticking with it in the end. FWIW McGaha has a lot of irons in the fire with other toys he has. A friend runs his Engine Shop.
