Page 1 of 6 1 2 3 4 5 6
Best combo for 600 HP Street Strip Car? #2324638
06/21/17 12:15 PM
06/21/17 12:15 PM
IL
Dart451 Offline OP
Dart451  Offline OP
IL
Wanting to see what combo people would use for street strip 600 hp big block. shift around 6000-6500 rpm,
400 or 440 base?
Heads?
cam?
Who's Crank/stroke?
Who's Rods?
Who's pistons/Compression?
This would be for a dragweek car.
Re: Best combo for 600 HP Street Strip Car? [Re: Dart451] #2324654
06/21/17 12:32 PM
06/21/17 12:32 PM
So. Burlington, Vt.
fast68plymouth Online content
fast68plymouth  Online Content
So. Burlington, Vt.
My suggestion would be:
10:1-10.5:1 505, TF heads, small street roller cam.
If I were building it for my own use, since I like doing my own heads......I'd use Indy EZ's.
Actually...... If I were going to build it right now...... I'd use what I have on hand......
Which is a low deck 511 rotating assy with flat tops, and some 84cc E Street heads.
You can easily get to the pump gas 600-650hp mark with a bb stroker many different ways.
Re: Best combo for 600 HP Street Strip Car? [Re: Dart451] #2324696
06/21/17 01:37 PM
06/21/17 01:37 PM
IL
Dart451 Offline OP
Dart451  Offline OP
IL
I need your part collection wrench , sell it to me for a great price, will be there this weekend punkrocka
Thanks for reply
Re: Best combo for 600 HP Street Strip Car? [Re: fast68plymouth] #2324697
06/21/17 01:38 PM
06/21/17 01:38 PM
long time lurker, short time p...
P
PorkyPig Offline
PorkyPig  Offline
P
popcorn
Re: Best combo for 600 HP Street Strip Car? [Re: Dart451] #2324702
06/21/17 01:46 PM
06/21/17 01:46 PM
AndyF Offline
AndyF  Offline
Either a 400 or a 440 block will get you there so I'd use whatever fits the best. A 400 based 470 with TF will easily make 600 hp. In a 440 block I'd most likely use a 505 kit although you really don't need that many inches to make 600 hp. The 505 is just a really nice combo that goes together fairly trouble free.
Re: Best combo for 600 HP Street Strip Car? [Re: Dart451] #2324706
06/21/17 01:58 PM
06/21/17 01:58 PM
lancaster,california
johnnycuda Offline
johnnycuda  Offline
My Cuda has about 620hp at the flywheel, runs mid-10s on pump 91, would love to run DW, did run the Drag Weekend they had.
Mine is a 440 block, Eagle 4.15 crank, Eagle stock length rods,10.5 compression, Indy SR heads that I've had for almost 20 years, .607/.601 lift solid roller, Indy single plane, 950HP Holley, MSD ignition, 2" primary headers, old school Top Ten Shootout 3" Flowmasters that haven't been made for 10 years or more.
Car weighs a little over 3800 w/me in it, 4.56 gear, 727 with too tight of a convertor, 295/65 drag radial.
1970 'Cuda,Lime Light,499 Indy S/R's 10.70's @125,street driven ALOT!
1966 Barracuda 360,now a 5spd,Hemi Orange,Hot Rod Air,
New daily driver-2003 Ram 2500 Cummins 5.9
'69 Valiant 2-dr, sleeper!
New project---1938 Dodge truck, plan is a 360 with a A500, AC, Calvert rear susp., rack and pinion front with coils.
Re: Best combo for 600 HP Street Strip Car? [Re: Dart451] #2324747
06/21/17 02:51 PM
06/21/17 02:51 PM
IL
Dart451 Offline OP
Dart451  Offline OP
IL
My dragweek car spun #6 rod bearing last friday.
440 stock stroke, ported iron heads, 590 mopar cam, crane 1.5 roller rockers. Running 10.9 in decent air.
Will get pistons out in the next couple days suppose to be 10.5/1 compression. Stock rods.
Engine had a lot of passes on it and I of refreshed it. The big surprised was the block is filled with hard block. So now trying to decide my best option and more power stirthepot
Do have a stock 400 "56k mile" sitting on engine stand.
Re: Best combo for 600 HP Street Strip Car? [Re: Dart451] #2324769
06/21/17 03:13 PM
06/21/17 03:13 PM
Take that 400 lock and have it sonic tested, if it has no less than .160 cylinder wall thickness now on both the major and minor thrust surface use it to make a 505 to 512 C.I. pump gas stroker up
My first 505 C.I. 400 stroker motor made 612 HP at 5500 RPM and 544 Ft lbs. torque at 4500 RPM with a set of midly ported 906 iron heads with 2.14 intake and 1.81 exhaust valves. they barely flowed 266 CFM at .600 lift puke I used a low deck six pak with a set of 1970 OEM 440 carbs. and a big Comp Cams soldi roller that was 260 @.050 on the intake and 266 @ .050 on the exhaust with 1.6 rocker ratio.
On your deal the same short block with a better set of new aluminum heads and a good single plane intake would make 650 HP easy with the same compression ratio on pump gas up scope
Re: Best combo for 600 HP Street Strip Car? [Re: Dart451] #2324801
06/21/17 04:20 PM
06/21/17 04:20 PM
So. Burlington, Vt.
So. Burlington, Vt.
Just plug a 493/505 rotating assy into that block..... You should be good to go.
Re: Best combo for 600 HP Street Strip Car? [Re: Dart451] #2324803
06/21/17 04:23 PM
06/21/17 04:23 PM
IL
Dart451 Offline OP
Dart451  Offline OP
IL
Who rotating assembly is recommended? My time frame will be tight dragweek sneaks up quick.
Re: Best combo for 600 HP Street Strip Car? [Re: Dart451] #2324809
06/21/17 04:35 PM
06/21/17 04:35 PM
So. Burlington, Vt.
So. Burlington, Vt.
For that power level, it hardly matters.
Just use name brand stuff and you should be fine
Re: Best combo for 600 HP Street Strip Car? [Re: Dart451] #2324816
06/21/17 04:58 PM
06/21/17 04:58 PM
IL
Dart451 Offline OP
Dart451  Offline OP
IL
Looking more for who has the best machine work. Get blocked prepped and just bolt together and race.
Re: Best combo for 600 HP Street Strip Car? [Re: Dart451] #2324819
06/21/17 05:01 PM
06/21/17 05:01 PM
an8sec70cuda Offline
I'd look at Molnar for crank and rods.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Best combo for 600 HP Street Strip Car? [Re: Dart451] #2324820
06/21/17 05:04 PM
06/21/17 05:04 PM
So. Burlington, Vt.
So. Burlington, Vt.
I've found it's kind of a crap shoot no matter what you get.
I guess if I was trying to stack the odds in my favor I'd use a Molnar crank and rods(but I'd still have them checked).
If Icon had a piston that would work for you, that would be my choice.
If they didn't....... Then any reputable brand that had what you needed.
Re: Best combo for 600 HP Street Strip Car? [Re: Dart451] #2324842
06/21/17 06:18 PM
06/21/17 06:18 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
here is a good piston spreadsheet, might have some CH pistons that will work for your application.
http://www.moparts.org/Tech/Archive/bb/BBM_Stroker_Pistons.html
Re: Best combo for 600 HP Street Strip Car? [Re: Dart451] #2324854
06/21/17 06:49 PM
06/21/17 06:49 PM
IL
Dart451 Offline OP
Dart451  Offline OP
IL
Will finish tear down and weigh my final options.
Thanks for link
Re: Best combo for 600 HP Street Strip Car? [Re: fast68plymouth] #2324870
06/21/17 07:21 PM
06/21/17 07:21 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Ditto...That is our combo...512 based 440 with EZ1 heads on pump gas with a 440 Source kit...Went 9.70 last week...10.8:1 roller cam...
Re: Best combo for 600 HP Street Strip Car? [Re: Dart451] #2324940
06/21/17 10:06 PM
06/21/17 10:06 PM
fullmetaljacket Offline
For best machine work give BEST Machine a call in Detroit.
Re: Best combo for 600 HP Street Strip Car? [Re: Dart451] #2324974
06/21/17 11:08 PM
06/21/17 11:08 PM
gregsdart Offline
gregsdart  Offline
It is hard to argue against the 400 based 512 cube combo, but consider a 440 at .030 or .060 over with a 4.5 stroke crank. That adds up to a 535 or 540 cubes.
With standard size port aluminum heads it is an absolute low rpm, high torque, 600+ hp monster.
Re: Best combo for 600 HP Street Strip Car? [Re: gregsdart] #2324998
06/21/17 11:40 PM
06/21/17 11:40 PM
Dragula Offline
Dragula  Offline
We are getting ready to put our 400/512 in...Basically the same combo from 440 source but with light weight crank in a 400 block.
We are hoping for a 9.59 with it....We will see. Can't wait to see if we hit 140mph with it. I was super impressed when we went 138.5 the other week with the 440/512....We have seven seasons on that and its due for a good freshen up or I may sell it and build an all aluminum low deck 512...We really like this and the 440/526 combo from 440 source. They make a ton of torque.
