Throttle cable recommendation 70 RR tunnel ram
#2324127
06/20/17 12:06 PM
06/20/17 12:06 PM
Posts: 2,414 St. Croix, US Virgin Islands
David_in_St_Croi
Hi, my throttle cable just broke, it corroded at the throttle linkage and. Car has stock pedal, Weiand tunnel ram. The linkage is the standard style to adapt to a throttle cable. Bracket on engine is one I made. Any recommendations on replacement? I think it was a stock cable originally. I have looked on Summit and the Lokar have a different end, not sure if it will work on stock pedal.
Re: Throttle cable recommendation 70 RR tunnel ram
[Re: David_in_St_Croi]
#2324219
06/20/17 02:45 PM
06/20/17 02:45 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
Back when I ran a tunnel ram on my 68 roadrunner I used a stock 6 cylinder cable. $5 bucks from the junk yard then, probably a little harder to find now 48 years later.
#2324526
06/21/17 02:45 AM
06/21/17 02:45 AM
Posts: 12,589 Great Neck,LI,new york
hemi-itis
Lokar stuff is nice if you can't find,,,,,,,
#2324545
06/21/17 04:22 AM
06/21/17 04:22 AM
Posts: 2,871 Pattison Texas
CSK
Pattison Texas
I got mine from Mancini, they can get them in any length.
#2324564
06/21/17 09:01 AM
06/21/17 09:01 AM
Posts: 632 MD-USA
Dodgeguy101
MD-USA
Thanks,
I will call around the couple of junk yards on island. Problem of course is the cable in the junkyard has been in the same warm salt air..... Mopars of this vintage are few and far between although there are a fair number of Dodge trucks
A search on Rock Auto for throttle cable for anything brings up zero results.
Best, Dave http://www.rockauto.com/en/catalog/dodge,1976,dart,5.2l+318cid+v8,1089064,interior,accelerator+cable,5892
